#1 S1 2+2: Front Frame 5/16-24 Fixed Nut Thread Issue
Posted: Tue Oct 22, 2024 8:08 am
Good morning,
So I am just prepping to re-attach the front frame on my restoration, needless to say I went to check all 24 5/16-24 holes and pre-welded nuts. 90% okay but found threading issues with the front left lower 4 OFF bolts which are welded (see photos).
Threads look to either to have been crossed in the past, or dare i say someone has fired in 5/16-18.
Just looking for advice, do i either re-tap 5/16-24 and add additional nut (nyloc) behind? or grind off and re-weld a single nut or helicoil existing nuts?
Slightly irritating as the tub is fully prepped and sprayed, but my fault for not checking originally :)
Will
Will
