3.8 LHD Re-Wire Routing around Steering Column
StefanS38
#1 3.8 LHD Re-Wire Routing around Steering Column
Post by StefanS38 » Tue Dec 17, 2024 5:41 pm
Hi Guys, Can anyone supply pictures of the original, or correct new wiring routing around the Steering Column Bracket? I did not take mine out, and am struggling to find confirmation as to where the looms lie. In particular where the engine bay loom sits, that comes in from behind the Voltage regulator, and up to meet the instrument panel loom. I do see the tabs, and understand they follow those, but what goes through the holes in the S /Column bracket? and up and down? (I have Autosparks Complete New Loom).Unfortunately No Restorative Publications show this. ( I have all of them ).And I do obviously have the correct Factory Manual wiring connection diagrams, showing relevant colours to instruments etc. Any help would be appreciated.
ysmalkie
Poland
#2 Re: 3.8 LHD Re-Wire Routing around Steering Column
Post by ysmalkie » Wed Dec 18, 2024 10:29 pm
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
ysmalkie
Poland
#3 Re: 3.8 LHD Re-Wire Routing around Steering Column
Would these help?
It's relatively original, beside obvious additions.
Tadek
Tadek
Jaguar XK120 OTS
StefanS38
#4 Re: 3.8 LHD Re-Wire Routing around Steering Column
Post by StefanS38 » Thu Dec 19, 2024 7:54 pm
Very Helpful. Thanks Tadek. Would you also have any showing the routing of the looms on bulkhead behind the Instrument panel? Regards Stefan
StefanS38
#5 Re: 3.8 LHD Re-Wire Routing around Steering Column
Post by StefanS38 » Sun Dec 29, 2024 4:09 pm
Hi Tadek, Or anyone else,Can you post a picture showing the way the loom sits on bulkhead behind the lowered instrument pannel? Do the early ones also have the two large 'P' Clips securing a thick wiring harness onto the bottom of the dash lid? I am having trouble working out how these thick black parts of the wiring harness lie in the centre behind the instrument panel. No pictures available in any books. Thanks Stefan
ysmalkie
Poland
#6 Re: 3.8 LHD Re-Wire Routing around Steering Column
Post by ysmalkie » Mon Dec 30, 2024 8:16 am
The 3rd photo is from a '62 flat floor, as you can see, it's the same arrangement as on my '63 car.
Tadek
Tadek
Jaguar XK120 OTS
