#1 Door latch star wheels
Posted: Tue Apr 08, 2025 1:39 pm
by alunwill
I'm at the stage of doing my shut lines before body prep and it's quite clear the star wheel bushes are well worn.
Is there anywhere you can get a refurbish kit for these latches.
Series 1, 2+2
Alun
#2 Re: Door latch star wheels
Posted: Tue Apr 15, 2025 2:32 pm
by alunwill
A useful fix.
Wobbly locks - worn bush, use the following part number from Accu, HSBF-12-16-19-PA. Bushes are £1.30 each, postage costs more than the part!
Basically a 12mm x 16mm x 19mm slide bearing with flange. You just need to slice one side with a hacksaw and it's a good fit.
I spot welded the shaft to the dog because you need to file the riveted end to get access.
Star wheels have no wobble but turn just fine.
Alun
#3 Re: Door latch star wheels
Posted: Wed Apr 16, 2025 12:32 am
Can you pop up a few pictures?
#4 Re: Door latch star wheels
Posted: Thu Apr 17, 2025 2:27 pm
by alunwill
#5 Re: Door latch star wheels
Posted: Tue May 06, 2025 11:14 am
by rfs1957
My variant on this relates to Series 1, where the star-wheel is indexed by a pawl that engages directly on the star-wheel's teeth, the ones that you can see from the outside.
Unlike the Series 2 which visibly indexes on the other side of the support bush.
My car has 2.50mm "slop" at the peak of the tooth, visibly due to the shape of the "pawl" rather than - perhaps - the original poster's concern about the bushing.
For a given position, with the door correctly closed, this may be irrelevant ; but I've run out of adjustment "inwards", and before I start drifting the threaded back-plate I would like to establish whether they are all like that ?
Am contemplating popping this open and reburbing everything, making new pins and bushes etc at the same time as I make new door hinge spindles.
#6 Re: Door latch star wheels
Posted: Wed May 07, 2025 8:06 am
by Allrand
I have the same problem as rfs 1957. Looking at Alun's pictures I think problem is play between the shaft and the inner star wheel, which welding has solved. I have a spare lock with the same problem which I'm going to open up and check.
#7 Re: Door latch star wheels
Posted: Wed May 07, 2025 9:07 am
by rfs1957
Look closely, Randall, as on my S1 the star/wheel latch is not at all like the one shown by Alun.
On his, indeed, the pawl indexes on an interior star-wheel - and where a welded repair could plausibly remove play between the inner and outer.
On mine, the pawl (and the locking mechanism, even) act on the same star-wheel body.
I'm not convinced that slop in the actual bush on mine would make any difference to the indexing, per se, and I'm even wondering whether the rotational slop in the tip (which is similar on both sides of my car) might not be deliberate, something along the lines of allowing for a recoil once the door has hit the rubbers.
Andy Rayner at Hutsons is going to have a look for me, they've got two Series 1 in the workshop right now.
(PS Are there any more available, helpful, and knowledgeable individuals in the trade than Andy Rayner ?)
#8 Re: Door latch star wheels
Posted: Wed May 07, 2025 11:07 am
by rfs1957
#9 Re: Door latch star wheels
Posted: Thu May 08, 2025 2:28 pm
by Allrand
