Finding a replacement battery
Lainston
#1 Finding a replacement battery
Post by Lainston » Wed Apr 30, 2025 2:40 pm
Hi, I needed a replacement battery for my Series 1 (1966) and was recommended a couple - most recently the Yuasa 1000 which, while it fitted the tray, did not fit the top plate.
Does anyone have any recommendations? (preferably nothing Chinese!)
thanks
#2 Re: Finding a replacement battery
Post by Gfhug » Wed Apr 30, 2025 2:46 pm
A search on here for battery in the topic title (advanced search) gives this
viewtopic.php?f=3&t=17710&p=144531&hili ... ry#p144531
Reference is given to the Halfords HB30 which seems to be discontinued, but they have a similar one HCB068.
As can be expected prices have increased to circa £130.
There are other batteries from Tayna you can search for approx CCA and then check the sizes
Lainston
#3 Re: Finding a replacement battery
Post by Lainston » Wed Apr 30, 2025 2:53 pm
Yes I saw that & found the 030 was no longer available - before trying a third battery I wondered whether anyone else had recently had success in fitting the alternative - as the post you refer to notes, advertised dimensions can differ from reality!
#4 Re: Finding a replacement battery
Post by Heuer » Wed Apr 30, 2025 3:43 pm
The 030 battery is a standardised size (the HB stands for Halfords Battery) so check out this one: https://www.thebatteryshop.co.uk/yuasa- ... 8774-p.asp
You will see it has 030 and the 068 equivalent numbers in the code. Yuasa are very high quality and fitted as standard to Toyota/Lexus cars.
265bhp
#5 Re: Finding a replacement battery vent used the car for a month can provide enough crank
Post by 265bhp » Wed Apr 30, 2025 7:27 pm
Not to everyone’s taste as it is red…however Optima AGM batteries have really strong cranking capacity for their size…and in winter when I have not used the car for a few weeks will turn the engine over enough times to coax a cold grumpy engine into life….
Knightrider
#6 Re: Finding a replacement battery
Post by Knightrider » Mon Sep 22, 2025 3:16 pm
Question for OP - did you ever find something suitable for the top plate? I am having the same issue - documented 030 dimensions are often larger than the top plate allows, although some batteries are smaller than documented.
Before I go trial and error, has anyone fitted a battery recently that definitely fits the top plate and tray, with the posts at the front the correct way round? Thanks!
1966 Series 1 2+2
PierreW
#7 Re: Finding a replacement battery
Post by PierreW » Wed Sep 24, 2025 7:05 am
The easiest thing would be for you to take the top plate and go and try it out in the shops....or not? :wink:
Jaguar MK2 1967 since 1980
Lotus Seven 1963 since 2015
XKE S1 1964 OTS since 2023
Knightrider
#8 Re: Finding a replacement battery
Post by Knightrider » Wed Sep 24, 2025 12:53 pm
I'm going to try that this weekend. In the UK, many parts stores don't have everything out on the shelf so can be tricky - Halfords is the only one I can think of where I can actually try!
I will update if I find something suitable.
1966 Series 1 2+2
#9 Re: Finding a replacement battery
Post by mgcjag » Wed Sep 24, 2025 1:50 pm
Some small car parts shops have batteries "out the back" so you have to ask...also farm supplies outlets and Agricultural supplies have quite a few if your rural...Steve
Knightrider
#10 Re: Finding a replacement battery
Post by Knightrider » Wed Sep 24, 2025 6:24 pm
So I just went to Halfords armed with my brand new top cage - not sure where it is from, but looks similar to the kit supplied by SNB.
The newer version of the Halfords battery linked above (068) doesn't fit - it is slightly too long. A 005 does, but is a little too high to fit under the heater box. 012 and 063 fit (a bit shorter but will clamp in place fine). They have lower capacities (450cca) - not sure if that will cause a problem?
1966 Series 1 2+2
Iansparky
#11 Re: Finding a replacement battery
Post by Iansparky » Fri Sep 26, 2025 8:36 am
I also bought a halfords battery, I can't remember which one though but I had trouble getting the top plate to fit, the problem was that the bit where the terminals connect was lower than the rest of the battery, the leads could not come from behind aa the posts were too low.. if i bought the leads from the front or sides they would touch the top plate , I ended up making a piece of wood to pack the plate up and machining some terminal extenders with an m8 thread, I then tapped the battery posts m8 and screwed the extenders in , this allowed the leads to miss the plate.
1965 series 1 ots
1972 triumph spitfire
2016 Caddy van
#12 Re: Finding a replacement battery
Post by mgcjag » Fri Sep 26, 2025 8:45 am
See similar topics below....the top clamps if not original typically dont fit and need work....Steve
Knightrider
#13 Re: Finding a replacement battery
Post by Knightrider » Fri Sep 26, 2025 6:07 pm
So to update - a Halfords HCB005 fits well. It is slightly shorter than the clamp plate, but the same width. With the included rubber inserts it holds down securely with the terminals correctly configured:
1966 Series 1 2+2
#14 Re: Finding a replacement battery
Post by DWW » Fri Sep 26, 2025 9:19 pm
On my Halford battery, don't remember which, I had to slightly chamfer the locking frame adjacent to the terminals as they seemed too close to the frame.
