Rear lights gasket to body fitting
Danny Lee
#1 Rear lights gasket to body fitting
Post by Danny Lee » Tue Sep 16, 2025 5:16 am
So today I’ve bee trying to fit the rear lights on my flatfloor…… in previous restorations I’ve cheated and used a very fine u shaped seal….this time I cannot, as I am wanting to make this car as original as possible…cue the problem!
I have several sets of gaskets …even som NOS Lucas ones…..but I cannot get them to fit no matter how I try…. So it means 1 of 2 things:
Either I have got the worst technique in fitting them OR
The gaskets are not fit for purpose.
I’ve tried gluing , spots of superglue , stretching, etc
So I’d like to know how others manage !
#2 Re: Rear lights gasket to body fitting
Post by abowie » Tue Sep 16, 2025 6:43 am
They often don't fit, unfortunately.
andrewh
#3 Re: Rear lights gasket to body fitting
Post by andrewh » Fri Sep 19, 2025 7:24 am
Are you aware that there are different gaskets for FHC and OTC? I have built both cars with new gaskets and there can be some patience required but they fit absolutely fine. You may have the wrong gaskets for your body.
Edit: my memory may be playing tricks, the light units are definitely different OTS to FHC, and early FHC reputedly has a different profile light . I cannot say for sure that the rubbers are different as I have memory fog, but a quick look at SNG Barratt website should tell you if the part numbers are the same
1962 3.8 Series One FHC
Danny Lee
#4 Re: Rear lights gasket to body fitting
Post by Danny Lee » Sat Sep 20, 2025 1:56 am
Thanks …yes I was aware of the differences ….. I’ll buy some of the latest iteration and scc how they fit!
Philk
#5 Re: Rear lights gasket to body fitting
Post by Philk » Sun Sep 21, 2025 5:30 pm
Fully agree. I found I had to do some internal cuts so they then stretched appropriately around the outer edge of the casing
1964 S1 3.8 OTS
#6 Re: Rear lights gasket to body fitting
Post by abowie » Mon Sep 22, 2025 12:36 am
What I do is grind the edge of the light fitting so it fits the body. It's die cast so it won't rust.
I then use superglue and glue the gasket to the light fitting.
I then offer this up to the body. If there are any gaps I use black silicone sealant to fill them.
Annoyingly slow but you usually get an acceptable result.
