#1 Retrofit gas strut to series 1 2+2?
Posted: Wed Sep 17, 2025 8:12 am
by Knightrider
My left-hand bonnet balance link is broken so I will be looking to replace them when I refit my bonnet. Before I order, I was wondering if anyone has retrofitted a gas strut to the series 1 cars to make life easier? Most of the available struts/brackets seem to be specific to the series 2?
#2 Re: Retrofit gas strut to series 1 2+2?
Posted: Wed Sep 17, 2025 8:53 am
#3 Re: Retrofit gas strut to series 1 2+2?
Posted: Wed Sep 17, 2025 10:10 am
by Gfhug
One thing to remember is that the attachment point on the bonnet is a strengthening plate. I’ve not read all the Jaglovers Steve has referred to, maybe it is mentioned there also.
#4 Re: Retrofit gas strut to series 1 2+2?
Posted: Wed Sep 17, 2025 11:33 am
by Knightrider
Useful thread - thanks. A bit more involved than I want to go I think - I'd rather not do anything irreversible. I guess I was hoping someone had developed a bolt-on adapter!
New balance links it is...
#5 Re: Retrofit gas strut to series 1 2+2?
Posted: Wed Sep 17, 2025 11:37 am
Did you see the last post on JL.... its one drilled hole and a large washer.....Steve
#6 Re: Retrofit gas strut to series 1 2+2?
Posted: Wed Sep 17, 2025 1:19 pm
by Knightrider
Using the clutch master arm? Neat idea, but as Geoff has said wouldn't the bonnet need strengthening?
#7 Re: Retrofit gas strut to series 1 2+2?
Posted: Thu Sep 18, 2025 7:48 am
Bonnet strengthened by the large washer...or asmentioned in the link use a plate with rivnuts or even rivets rather than weld....very simple diy solution....Steve
#8 Re: Retrofit gas strut to series 1 2+2?
Posted: Thu Sep 18, 2025 9:33 am
by Knightrider
I'll look into it! On series 2 cars, there is only a strut on one side - is the other side just the hinge pin, or is there a balance spring as well?
#9 Re: Retrofit gas strut to series 1 2+2?
Posted: Thu Sep 18, 2025 9:43 am
by Gfhug
Only the strut on one side
#10 Re: Retrofit gas strut to series 1 2+2?
Posted: Thu Sep 18, 2025 1:02 pm
by Knightrider
I've just found this old post as well:
viewtopic.php?t=4512#p110010
Looks like the strut is mounted to the original balancer bracket? Quite a nice solution with no permanent changes - not sure if the strut is the same as the series 2 or a different length to make it work though.
