I've seen a few references where the traditional outer felt oil seals on the rear fulcrum shafts have been replaced by a one piece rubber version.
Has anyone used these and if so would they be kind enough to share the part number and supplier.
Rear ub carrier outer fulcrum seal
#1 Rear ub carrier outer fulcrum seal
Al
Series 1, 2+2
undergoing renovation
Series 1, 2+2
#2 Re: Rear ub carrier outer fulcrum seal
You can replace any seal by quoting the shaft dia, seal o.d., seal width, seal type and material. This one measures 1.125" x 1.625" x 0.25" with a regular lip seal, probably neoprene.
I used them when I restored my 3.8 years ago, worked fine, I think the CR # was CR11124. Probably SKF now.
Clive, 1962 Coupe 860320
(sold)
(sold)
