#1 Separating front hub from disc
Posted: Sun Oct 12, 2025 4:28 pm
I started what I thought would be a simple job this afternoon - removing the front discs to either clean them up or replace them. I have removed the hub assembly fine - caliper off, pin out, castle nut off. I have also removed the 5 bolts securing the disc to the hub.
But...the disc is stuck fast to the hub. No matter how much persuasion I use, I cannot separate them. Any tips? I don't have access to a press....
