#1 Torpedo armrest screws
Posted: Sun Nov 30, 2025 1:16 pm
by Knightrider
My Series 1 2+2 has torpedo-style armrests. I am trying to figure out the correct size screws to fit them - they currently seem to be fitted with a variety of different wood screws...
Does anyone know a source for correct size screws? Thanks.
#2 Re: Torpedo armrest screws
Posted: Sun Nov 30, 2025 2:48 pm
Hi Simon..have you looked at the parts catalogue for the part number...then check on that....Steve..ps you could remove the door cards and check the threads assuming they arnt damaged...but if someone has used wrong screws the threads could be damaged and need repair
#3 Re: Torpedo armrest screws
Posted: Sun Nov 30, 2025 3:23 pm
by Knightrider
Annoyingly the MR catalogue shows the screws coming with the handle, and doesn't lost the screws separately.
I might just re-tap the threads to M5 which seems to be the closest.
#4 Re: Torpedo armrest screws
Posted: Sun Nov 30, 2025 3:38 pm
by tim wood
I have a recall that mine were 1/4 unf. I used Allen headed bolts
#5 Re: Torpedo armrest screws
Posted: Sun Nov 30, 2025 6:55 pm
by Knightrider
1/4in definitely too big. Looks like they are just smaller than 5mm...
#6 Re: Torpedo armrest screws
Posted: Sun Nov 30, 2025 7:04 pm
Probably 10/32... Steve
#7 Re: Torpedo armrest screws
Posted: Sun Nov 30, 2025 7:53 pm
by tim wood
I stand corrected!
#8 Re: Torpedo armrest screws
Posted: Sun Nov 30, 2025 7:54 pm
by tim wood
I stand corrected!
Apologies
#9 Re: Torpedo armrest screws
Posted: Sun Nov 30, 2025 9:07 pm
by Knightrider
I'll order some 10/32 unf and see if they fit...
#10 Re: Torpedo armrest screws
Posted: Sun Nov 30, 2025 9:59 pm
by 40GT
They are 10/32 unf, mine are pan head Pozi about 1.25 inch long.
#11 Re: Torpedo armrest screws
Posted: Mon Dec 01, 2025 12:56 am
From experience I'd recommend you use hex heads, or at least Philips head.
A flat head slotted screw can be hard to keep aligned in the recess in the armrest.
#12 Re: Torpedo armrest screws
Posted: Mon Dec 01, 2025 11:03 am
by Knightrider
Thanks all. Will try hex head if I can find some!
