#1 Camshaft alignment in warped cylinder head???
Posted: Thu Jan 29, 2026 8:27 am
by PierreW
A big question has been on my mind for a long time.
If we have to resurface a cylinder head, it's because it's "bent" or "warped". After resurfacing, it ends up flat...that's the goal :-) Yes! But what happens to the alignment of the camshaft bearings, which are still in a cylinder head that remains bent but is now "straight" ?
#2 Re: Camshaft alignment in warped cylinder head???
Posted: Thu Jan 29, 2026 11:02 am
by Series1 Stu
If you do the job properly, you line bore the camshaft bearing journals and fit oversize bearings.
I assume that the reputable engine reconditioners do that. Or maybe they have some other way of getting it true?
#3 Re: Camshaft alignment in warped cylinder head???
Posted: Thu Jan 29, 2026 1:31 pm
by Gfhug
Stuart, I’ve been told the cam bearings surfaces can not be ground and there’s therefore no different size bearings. Or maybe I’m misinterpreting your advice or what’s been told me. SNGB don’t show larger cam bearings.
If the head is being resurfaced isn’t that normally because of corrosion rather than distortion?
Regards, Geoff
#4 Re: Camshaft alignment in warped cylinder head???
Posted: Thu Jan 29, 2026 2:14 pm
Typically a head is resurfaced due to corrosion...if its measured and found to be too warped then its find a new one time.....Steve
#5 Re: Camshaft alignment in warped cylinder head???
Posted: Thu Jan 29, 2026 5:22 pm
by Geoff Allam
There has been mention in various posts over the years of warped heads being straightened by bolting them to a flat plate and then heating in an oven. I believe it was also reportedly quite commonly done at Classic Jaguar in Austin Texas. I have no personal experience but hopefully someone like Bill Angel can comment.
#6 Re: Camshaft alignment in warped cylinder head???
Posted: Fri Jan 30, 2026 11:05 am
by Allrand
Check the alignment of the cam bearings with a good straight edge. The center two tend to be higher if the head is warped. I had my Mk 7 successfully linebored by removing some material from the mating surfaces of the bearing caps. A good engineering shop should be able to do this.
#7 Re: Camshaft alignment in warped cylinder head???
Posted: Fri Jan 30, 2026 9:50 pm
I've not seen the cam bearings linebored on any of our rebuilds. It just doesn't seem to be an issue.
If you were to do it I'd expect that what you'd do is grind material off the bottom of the cap then correct the alignment, the same way you do rod journals, so you wouldn't need oversize bearings.
