Could someone advise me on what would be the typical gap between roof underside and the top of the door window frame. I have 1/2" on one side and 1/2 tapering to 5/16 on the other. I have new doors, old frames and cill to roof gap is same both sides.
I've searched through the knowledge base but failed to find the information.
Alun
Top of the door frame gap
#1 Top of the door frame gap
Al
Series 1, 2+2
undergoing renovation
Series 1, 2+2
#2 Re: Top of the door frame gap
I have a similar problem. The difference was in the doors. These cars wern't welded by bots. You can put some shims under the frame where it attaches to the top of the door to even them out, or just live with it because you cant lower the frame without some cutting/bending/welding somewhere.
Randall Botha
#3 Re: Top of the door frame gap
The gap on my car is around 1/4 inch and 3/8 at curve of top front corner.
Mike
1969 S2 FHC
1969 S2 FHC
#4 Re: Top of the door frame gap
Randall is quite right, differences in doors to frames isn’t unusual and compromise is often the way with these cars. Do a trial fit checking the rear side window to the door frame and door to car. Each can affect the look, especially of the door window frame to B post and at the top as you are finding. Have you fitted the door seals at the front as they need to be in before fitting the door? The seals at the top can fill the gaps so that can help.
#5 Re: Top of the door frame gap
Many thanks for the information. I've shimmed as suggested and end up with a 7mm gap across the top.
Geoff, I do have the seals in place. A post is fine. The B post seals however barely touch at the top.
The seal is a good uniform fit up past the door but it runs out as it goes up the window frame. The door gaps are good so to have this runout at the top of the B post is anoying. Is this normal or am I missing something.
Alun
Alun
Al
Series 1, 2+2
Series 1, 2+2
#6 Re: Top of the door frame gap
Have a look here https://forums.jag-lovers.com/
#7 Re: Top of the door frame gap
Alun, did you buy your seals from Baines? I seem to remember all their seals come over length so you can trim to size. https://coh-baines.co.uk/
