#1 oil sump draining before working on oil return???
Posted: Thu Jun 25, 2026 7:34 pm
by PierreW
Just so I don't end up covered in oil while I'm working on it! :wow: Is it necessary to drain the sump before removing the oil pump return line? I have a major leak where the elbow connects to the sump.
#2 Re: oil sump draining before working on oil return???
Posted: Thu Jun 25, 2026 8:41 pm
by flatfloor 3.8
Yes
#3 Re: oil sump draining before working on oil return???
Posted: Fri Jun 26, 2026 6:14 am
by Simonpfhc
If you have access to a car lift, no, it is not necessary. If you place just the front wheels on the lift and raise it, the car (and engine) will end up at an extreme angle and the oil level will clear the return pipe.
I replaced mine this way.
#4 Re: oil sump draining before working on oil return???
Posted: Fri Jun 26, 2026 9:34 am
by PierreW
[ the car (and engine) will end up at an extreme angle and the oil level will clear the return pipe.
[/quote]
And with this method, we might also be able to see if the engine seal on the gearbox side is leaking...?
#5 Re: oil sump draining before working on oil return???
Posted: Fri Jun 26, 2026 11:30 am
by Simonpfhc
The rope seal requires the crank to be turning to be effective, so with this much oil sitting over it, it will almost certainly start dripping. So, unfortunately, not a good way to see if it leaks.
Unless, of course, the oil pours out :lol:
#6 Re: oil sump draining before working on oil return???
Posted: Fri Jun 26, 2026 12:12 pm
by PierreW
I was thinking more of the sump gasket, not the rope seal one.
#7 Re: oil sump draining before working on oil return???
Posted: Fri Jun 26, 2026 1:07 pm
by bitsobrits
While you may have lived to tell the tale, I would highly recommend not loading a car lift (especially a two post) in such an asymmetric manner. The angle required to prevent oil egress would be extreme, and in my view extremely dangerous.
So much safer to just drain the oil. And if you're cheap, drain the oil into a clean container and re-use it.
#8 Re: oil sump draining before working on oil return???
Posted: Fri Jun 26, 2026 5:55 pm
by flatfloor 3.8
Totally agree with Steve in above comment just drain the oil and don't risk having an accident.
#9 Re: oil sump draining before working on oil return???
Posted: Fri Jun 26, 2026 8:33 pm
by Simonpfhc
Mine’s a scissor lift so very safe. Totally agree about avoiding this with a two-post though.
#10 Re: oil sump draining before working on oil return???
Posted: Sat Jun 27, 2026 7:06 am
by PierreW
Let's go for a drain :bigrin:
#11 Re: oil sump draining before working on oil return???
Posted: Sat Sep 05, 2026 7:05 am
by PierreW
problem solved !
