#1 Aftermarket heater fan internal short
Posted: Sat Jun 27, 2026 1:57 pm
by Knightrider
Very frustrating and odd problem this morning... I know it's not really the weather to be talking about heater fans, but I turned mine on the other day due to an overheating issue (whole other story) and every time it turned on fuse 7 would blow. I have a virtually brand new Martin Robey uprated fan that I installed last year and initially tested fine, so assumed it was a wiring/switch issue. Spent several hours tracing and testing the switch and wiring and no obvious shorts or issues.
Disconnected the fan motor and ran it directly from an external battery - pulling 2A on low setting and 4A on high - no obvious issues. Tried again using the battery in the car, with the car ground wire connected to the battery, and suddenly current increases and the motor smokes. Quick test confirms that the green/yellow and green/blue wires are shorting to the metal casing.
On dismantling the motor, I found this inside:
The wires connect to the motor brushes with around 1cm exposed. The brushes sit in the plastic plate, pushed onto the motor by springs. The plastic base plate had broken, allowing the live wire to move and intermittently touch the outer casing causing a short.
Putting this here for info, (1) to help anyone else chasing a similar problem in the future, and (2) to see if anyone else has had similar issues with aftermarket motors? I have contacted MR to see if they will provide a replacement under warranty.
Not helped by the fact that every time I turned on the ignition to test this morning, my rear carb overflowed as the float has sunk...
#2 Re: Aftermarket heater fan internal short
Posted: Sat Jun 27, 2026 4:02 pm
by bitsobrits
Overflowing carbs are much more likely due to a varnished (gummy with fuel residue due to lack of use) or worn needle valve. Floats do leak and 'sink', but that is relatively less likely to occur.
#3 Re: Aftermarket heater fan internal short
Posted: Sat Jun 27, 2026 4:10 pm
by Knightrider
I've pulled it apart - definitely sunk and full of fuel!
#4 Re: Aftermarket heater fan internal short
Posted: Sat Jun 27, 2026 8:46 pm
by Series1 Stu
Uprated fan (or any other part) generally means someone has found a dirt cheap part that vaguely fits the space the original, carefully specified, item resides.
That fan motor looks like it was made by people who don't have any history of making anything remotely similar to it.
Aftermarket parts! :banghead:
#5 Re: Aftermarket heater fan internal short
Posted: Mon Jun 29, 2026 9:03 pm
by Knightrider
Does seem that the plastic mounting plate is too weak for the motor design.
Martin Robey great as always and sent another one straight out. They'll send the broken one back to the supplier.
