Shaft repair sleeves
alunwill
#1 Shaft repair sleeves
Post by alunwill » Thu Jul 30, 2026 8:25 pm
My companion flange on the input drive to the diff has a groove from the oil seal.
Has anyone had experience of using a speedy sleeve to overcome potential leaks from this type of problem. If so, were there any issues regarding the life of the oil seal because of the increased shaft thickness.
Many thanks
Alun
Al
Series 1, 2+2
undergoing renovation
#2 Re: Shaft repair sleeves
Post by abowie » Thu Jul 30, 2026 11:14 pm
They're only a few thou thick. No problem with using them at all.
mxke
#3 Re: Shaft repair sleeves
Post by mxke » Fri Jul 31, 2026 3:13 am
I've used them many times. Never a problem.
Tech396
#4 Re: Shaft repair sleeves
Post by Tech396 » Sat Aug 01, 2026 5:55 am
Highly recommended and use loctite (as a sealer) to prevent weeping.
