Looking for a Softer Hatch Seal for a Series 1 FHC
Wallace
#1 Looking for a Softer Hatch Seal for a Series 1 FHC
Post by Wallace » Tue Aug 04, 2026 9:25 am
Hello,
I’m the proud owner of a Series 1 4.2 FHC, which I’ve been restoring for the past five years. I’m finally nearing the finish line, and this forum has been an invaluable source of information and advice throughout the restoration.
However, I’ve been stuck for several weeks on one last detail. I simply cannot install the hatch seal that fits onto the body aperture. The PVC seal I purchased from SNG Barratt is far too stiff and is almost impossible to fit around the curved sections.
I’ve noticed that some cars appear to use a much softer seal, but I haven’t been able to find a supplier that sells this type.
Does anyone know of a supplier offering a softer hatch seal?
I’ve attached a photo to avoid any confusion about which seal I’m referring to.
Thank you in advance for any advice.
Eric
#2 Re: Looking for a Softer Hatch Seal for a Series 1 FHC
Post by Gfhug » Tue Aug 04, 2026 9:44 am
Have you spoken to COH Baines? They make lots of very good seals
#3 Re: Looking for a Softer Hatch Seal for a Series 1 FHC
Post by mgcjag » Tue Aug 04, 2026 10:30 am
Same issue here its not a seal its a trim piece.BD39105..you need to look for old stock..new after market is way too hard ..ps you could try soaking it in hot water? Or try the trimmers see what they use..Aldridge BAS etc viewtopic.php?f=3&t=22097&p=177929#p177929
Wallace
#4 Re: Looking for a Softer Hatch Seal for a Series 1 FHC
Post by Wallace » Wed Aug 05, 2026 5:25 am
Thank you for your feedback.
I contacted Baines, but unfortunately they do not supply this part.
I’m going to try Aldridge, as I actually bought the interior trim kit from them.
#5 Re: Looking for a Softer Hatch Seal for a Series 1 FHC
Post by abowie » Wed Aug 05, 2026 9:04 am
Odd. I've fitted any number of the seals from SNGB and they've always been fine. They're not PVC but soft rubber.
Have you reached out to them?
Alternatively try David Manners.
Wallace
#6 Re: Looking for a Softer Hatch Seal for a Series 1 FHC
Post by Wallace » Thu Aug 06, 2026 4:48 am
No, not directly. I simply ordered the part number online.
It can’t hurt to contact them, so I’ll give them a call.
