#1 What's it like living with a moss box?
Posted: Wed Aug 05, 2026 4:57 pm
by mattpettitt
Hi all, I'm looking at S1/S2's - there's a lot I love about the S1 3.8 but just how bad is the moss box to actually live with if you're doing a fair amount of driving with it? Is it something you eventually get used to or does it detract from some of the driving experience (or perhaps even add to it)?
The upgrade to a more modern 5-speed syncro would be cost-prohibitive, at least initially and yes, I'll have a test drive but using it for 30 minutes wouldn't be enough to really understand any challenges I think.
Any thoughts?
cheers,
Matt
#2 Re: What's it like living with a moss box?
Posted: Wed Aug 05, 2026 6:32 pm
by Stevemorris
Hi Matt, I have a 4.2 S1 so mine doesn't have a Moss box, but I have had MKII's with the same box.
First gear has a longer throw. Not an issue but it's the similar position to reverse, some say they have inadvertently selected reverse when looking for first, I never experienced that personally.
They are slightly noisier in the lower ratios, and with no synchro on first selecting it before the car has stopped can be a little tricky. Upside is they are very strong.
Personally, I like the Moss box, it has character. Im not an advocate of switching to 5 speed boxes, I believe cars should be kept as the manufacturer intended, but that's just me!
Steve.
#3 Re: What's it like living with a moss box?
by bitsobrits
I've had two Moss box cars, and now my current 4.2 car which I converted to a 5 speed a year or so after purchase.
I've no quarrel with a Moss gearbox in an old sport tourer. Yes, you can't downshift into 1rst with a single declutch, yes the change is a relatively slow 1 step, pause, 2 step process. But it fits the machine vintage and the way these cars are generally used these days. That said, the all synchro box was a revelation, and very modern in its feel. A 5 speed with the right gear spacing is to me is the choice, but acknowledge it's not to all tastes and budgets (especially as there isn't much choice these days in vendors).
So my summary would be to find a car that fits your taste and budget, and if it has a Moss box, just enjoy the drive. Even if your 0-60 or 0-100 time is a bit slower due to the gear change, you are still driving an E-type.
#4 Re: What's it like living with a moss box?
Posted: Wed Aug 05, 2026 6:48 pm
Plenty of info if you search...and see similar topics below...and here
viewtopic.php?f=2&t=19199
#5 Re: What's it like living with a moss box?
Posted: Wed Aug 05, 2026 8:13 pm
by Gfhug
I’ve not driven a Moss but having learned to drive on a full crash box (no synchro on any gear) once you’re used to it then you almost double declutch by (bad?) habit. Nothing to be afraid of imho and as advised above you’ll appreciate the car for how it was.
#6 Re: What's it like living with a moss box?
Posted: Wed Aug 05, 2026 9:40 pm
by dlgis
It takes a little getting used to, but adds to the fun of driving a classic car. As others have said it’s best to incorporate a momentary delay in the shift. Reverse and first are quite close together and you need to be careful to select the right one to avoid scaring the driver behind. Briefly moving into second before shifting to first can help. The lack of synchro on first is a non issue as the car has plenty of torque to proceed from nearly stationary (or even stationary) in 2nd, and if I’m going that slow I tend to stop and put it in first. And I do like the noise from the Moss box in 1st gear
#7 Re: What's it like living with a moss box?
Posted: Wed Aug 05, 2026 9:44 pm
by DWW
I had the moss box originally but now converted to a five speed which makes a huge difference and improves the driving experience no end,
#8 Re: What's it like living with a moss box?
Posted: Thu Aug 06, 2026 2:22 pm
by Allrand
Having grown up with 50's & 60's British cars and also owned Mk VII & Mk I with Moss boxes it's no problem, just don't rush it. Makes a delightful sound in 1st. As above shift into 2nd or just toward 2nd then straight up into 1st when stopped.
#9 Re: What's it like living with a moss box?
Posted: Thu Aug 06, 2026 4:24 pm
by mattpettitt
Cheers guys, appreciate all the comments (and the link to the other discussion!)
#10 Re: What's it like living with a moss box?
Posted: Sat Aug 08, 2026 5:34 pm
by Robbiee
I have moss box on my 1962 3.8 …personally I love it
It makes the correct sound in first.
DD clutching is fun especially 3 to 2 whilst slowing for a corner, it’s always a joy when it works smoothly
The moss box requires a mature timely approach when shifting ..very appropriate
I have an Etype Fab 5 speed on my coupe which is is just like a modern box ..it just lacks the classic feel
My advice: Embrace and enjoy the classic feel of the moss box
#11 Re: What's it like living with a moss box?
Posted: Mon Aug 10, 2026 8:12 am
by andrewh
I have my original Moss box in my 62 3.8. I was extremely keen to restore the car to original factory specification and except a Fosseway cooling fan its pretty much exactly that. When the box was rebuilt for me the specialist told me it was a good one in that the integral synchros were in good condition. I took the advice on here and filled it with a particular type of oil, ( can't recall but someone will remind me ) and to be fair it worked really better than I could have expected. However, as time has worn on so has my slight annoyance with the box. I have driven plenty of non synchro gearboxes and learnt on a series 2 Land Rover and a wartime Willys Jeep. If you allow yourself to lose concentration it will bite you back with an awful crunch. I am concerned that after I have stopped driving none of my 3 daughters will be able to master the box and I am actively considering changing it to a 5 speed in order to future proof the car. Frankly, if it is to be converted at some future stage, I would rather it be me than some grease monkey that will not show the same level of care and attention I did when restoring it from scratch. You have me thinking again and where I usually fail is in making the decision of which box to fit.
