#1 fuel filter won't fit
Posted: Sat Aug 29, 2026 8:32 am
by Philippe-J.
I purchased the only fuel filter I could find that was specified for a "glass bowl", as is mine.
But I discovered that this filter, ref C28080*, does not fit in my bowl (maybe not original).
Any idea of another reference for a fuel filter that would fit in this narrow bowl?
Thanks for helping.
#2 Re: fuel filter won't fit
Posted: Sat Aug 29, 2026 9:18 am
Worth having a read here....S1 typically had the disc gauze filter......many of these aftermarket paper filters filters dont work as per the original design by Jaguar....sediment collects inside the filter so can't be seen in the glass bowl.....what filter unit do you have is it E type?.....some jag models use a shorter filter....Steve viewtopic.php?t=13616
https://forums.jag-lovers.com/t/fuel-fi ... ned/393831
#3 Re: fuel filter won't fit
Posted: Sat Aug 29, 2026 12:05 pm
by PierreW
Thanks for helping.
[/quote]
I ended up with a completely clogged paper filter (though the blockage wasn't visible), which forced me to limp home at 5 km/h at 2 a.m.! So, I used a butane torch on it to salvage the metal parts. I then fitted a section of fuel oil filter onto the metal components and bonded everything together with 24 h epoxy. It’s been in place for three months now with no signs of the bond failing; however, you do have to remove all the original molded plastic parts, as they aren't resistant to gasoline—unlike heating oil.
Afriso Siku filter
#4 Re: fuel filter won't fit
Posted: Sat Aug 29, 2026 12:31 pm
Have you read through the info in the 2 links I posted...also is your filter an original E type unit?....was there a filter in the glass bowl previously?....Steve
#5 Re: fuel filter won't fit
Posted: Sat Aug 29, 2026 1:21 pm
by Philippe-J.
Steve, thank you for the links. I realize that a simple question calls for a complicated answer!
Nevertheless, I chose to try the GF124 AC Delco. It seems shorter than the SNG's, so could possibly fit into the bowl :fingerscrossed:
As for the originality of my filter and bowl, I am not sure at all. And I can't remember if the (paper) filter was in the bowl when I got the car. As a matter of fact I can't find it back today. However I found a brass filter mesh in the filter head.
Pierre's DIY would be a last chance solution.
#6 Re: fuel filter won't fit
Posted: Sat Aug 29, 2026 3:27 pm
by gjp
Hello, I use this one :
https://www.betaset.fr/fr/alimentation/ ... aguar.html
Works perfectly in original bowl.
BR
#7 Re: fuel filter won't fit
Posted: Sat Aug 29, 2026 4:10 pm
Philippe.....if you found a brass disc filter mesh in your filter head then that is the filter for the S1 cars...still available
#8 Re: fuel filter won't fit
Posted: Sat Aug 29, 2026 7:00 pm
by Philippe-J.
Thank you gjp, I'll make an order asap. At 8 euros, I can even order 2 of them :bigrin: !
Steve: I do have this brass disc filter mesh in the filter head. Question from a dummy: then do I need a paper filter too?
#9 Re: fuel filter won't fit
Posted: Sat Aug 29, 2026 8:55 pm
The round disc gauze filter was used for S1 cars as far as im aware....you dont use both.....look at the Jaguar parts catalogue part numbers...part number 7299.... Steve
#10 Re: fuel filter won't fit
Posted: Sun Aug 30, 2026 10:41 am
by Philippe-J.
Steve,
as a matter of fact, I bought that 7299 filter, but I was convinced I needed the paper filter too.
By pure chance, I looked at a 65 FHC, yesterday in a local show, and it had no paper filter: the glass bowl was empty, just full of fuel.
My quest was not justified, then.
Philippe
#11 Re: fuel filter won't fit
Posted: Tue Sep 01, 2026 7:58 am
by paydase
Steve,
Thanks for the clarification, I was also unsure whether to use both filters at the same time (thinking the gauze was for larger debris and the paper for fine ones).
Actually, in my 3.8 OTS I see the filter paper and on my 3.8 FHC the gauze one.
I will have to inspect if the OTS has both...
#12 Re: fuel filter won't fit
Posted: Tue Sep 01, 2026 8:15 am
What they had from the factory is listed in the Jaguar parts catalogue.....obviously a the disc gauze won't filter as fine a others.....so you have choices....Steve
#13 Re: fuel filter won't fit
Posted: Tue Sep 01, 2026 7:18 pm
by TGN
Was the old filter damaged?
They’re cleanable and reusable.
Assume you’ve checked the other 3 filters too?
#14 Re: fuel filter won't fit
Posted: Wed Sep 02, 2026 8:35 am
by Philippe-J.
My old (gauze) filter was quite dirty & a bit corroded
I can explain that by the long immobilization of the car somewhere in a californien barn.
For the price, I'll change it for a new one from SNG.
And yes I ordered paper filters from Betaset. Should receive them soon. I'll tell you how they fit.
#15 Re: fuel filter won't fit
Posted: Sat Sep 05, 2026 7:38 am
by Philippe-J.
On reception of the Betaset filters, it appears they are exactly the same as the ones of Barratt.
So they don't fit either :twisted:
I came to believe that MY bowl is not standard, with its conical shape.
I'll try a DIY mod...
