#1 Rear hubs and spacers
Posted: Thu Oct 08, 2026 7:55 am
by alunwill
Is it normal to have a 10 thou difference between left and right rear hub preload spacers.
I've replaced my rear hubs because when I stripped them initially they were blue. That is well heated.
I assumed they'd been run dry but now I wonder if having been set up with 110 thou shims, they were in fact just too tight with preload.
Whatever the original issue was, I have spacers which measure 128 and 138 thou when set for zero end float. Is the difference unusual.
Al
#2 Re: Rear hubs and spacers
Posted: Thu Oct 08, 2026 8:14 am
The spacer sizes are listed in the service manual....its not unusual to have a difference each side.....Steve
#3 Re: Rear hubs and spacers
Posted: Thu Oct 08, 2026 9:22 am
by alunwill
Morning Steve,
Many thanks.
Al
#4 Re: Rear hubs and spacers
Posted: Thu Oct 08, 2026 6:19 pm
by rfs1957
viewtopic.php?t=21809
Hi Al, maybe you have already read these exchanges, but worth looking at whilst you’re deep in there, my opinion now is that if you didn’t need a press to assemble and disassemble the paired hub bearings, then you need Loctite upon final assembly.
#5 Re: Rear hubs and spacers
Posted: Fri Oct 09, 2026 7:48 am
by alunwill
Hi Rory,
Yes I definitely needed a press. I've acquired a good range of short pipes that slip over the shafts.
Al
