#1 Speedo Cable through the bulkhead
Posted: Sun Apr 10, 2011 11:17 am
by ChrisC
Folks,
Can anyone tell me which bulkhead hole the speedo cable goes through?
Is it the one next to the steering column or the one on the side of the transmission tunnel?
Posted: Sun Apr 10, 2011 11:55 am
by PeterCrespin
It's the largish one directly behind the, err, speedo in the bulkhead.
There are always two for LHD/RHD with a blanking grommet for the unused one. Any number of pics on xkedata.com.
Posted: Sun Apr 10, 2011 12:15 pm
by ChrisC
thanks Peter but a little more information would help. I have 4 holes "behind the speedo" in the bulkhead 3 of which are "largish".
Would some kind person pop out to their car and let me know which one of the following it is?
1. at the top of the bulkhead above the steering column
2. slightly to the left of the steering column
3. slightly to the right of the steering column (and on the same panel)
4. on the transmission tunnel
Posted: Sun Apr 10, 2011 9:48 pm
by andrewh
this is on a 3.8 but it may be the same as a 4.2 I imagine. Hope it helps
Posted: Sun Apr 10, 2011 10:17 pm
by ChrisC
thanks Andrew. So what is the cable coming out slightly to the right of the steering column? Is that the choke cable?
Posted: Mon Apr 11, 2011 8:09 am
by andrewh
I will need to check that on the car so will post later on.
Posted: Mon Apr 11, 2011 8:14 am
Chris
Not sure if it will help but have a look at the LHD to RHD conversion guides in the Knowledge Base as there are a lot of photos detailing the bulkhead, for obvious reasons. http://etypeuk.com/forum/viewtopic.php?t=1664
Posted: Mon Apr 11, 2011 9:40 am
by andrewh
indeed you are correct , that is the choke cable. Good luck
Posted: Mon Apr 11, 2011 9:47 am
by ChrisC
Great thanks Andrew. That removes one of the options through the bulkhead.
