Good afternoon everyone. My car car is a late S1 roadster which has been fitted incorrectly with an early S1 Lucas (remade) ignition switch. The early cars, 3.8s were fitted with Lucas part No. 31962 (Jaguar No. C.15454), with two terminal, one of which is a double. I've checked this on my 1962 3.8 FHC and in the 1961-1963 parts book and the switch is this one. My car should have been restored using the later 1965-68 Lucas ignition switch No. 34679 (Jaguar No. C.22258) which has four terminals, one of which is a double, making five. I've attached an image of the early switch (not sure if this link works, never done this before) with the wiring attached in the car at the moment and the later 34679 switch. The question is, where do all these wires go?! None of the terminals on either switch are numbered. The reason for the retro fit of the original switch is the remade "PoD" item is broken, no surprise. On the wiring diagrams, from what I can see, there are only 4 wires attached to the switch for the later S1's. A picture or simple instructions as how to correct this would be most appreciated. Paul
PS If this image does note appear the
www.classicsailireland.com/leyc-a-class-colleen
Will take you to a page where the images are. Many thanks in advance. P.
