Body splash shield problem
lyons
#1 Body splash shield problem
Post by lyons » Sun Mar 20, 2011 4:44 pm
Fitting new / old stock body splash shields to car BUT the drivers side (RH) fouls badly on the rubber when closing the bonnet. Any ideas / comments from others who had had this problem and solved it.
Is it just a case of using brute force to bend where it should be !!! - difficult with the shaped crease in the metal.
Passenger side (LH) fits well.
Car is RHD OTS.
alangordonman
Post by alangordonman » Fri Jun 17, 2011 7:05 pm
You perhaps need to slightly adjust the fixing holes to lower the panel as well as bend the metal to fit. Alan
kingzetts
Post by kingzetts » Fri Jun 17, 2011 8:06 pm
I fitted reproduction panels, but faced the same problem. It was a matter of controlled brute force to alter the angle of the panel to clear the inner wheelarch, I'm afraid.
John '62 S1 OTS (now sold)
