DHC door glass problem
lyons
#1 DHC door glass problem
Post by lyons » Tue Jul 05, 2011 3:16 pm
After I attach the door glass to the winding mechanism, what stops the glass from winding right out the top of the frame. Am I missing a pin stop or something as I have chacked the parts manual and nothing is listed.
Thanks for any help
PeterM
Post by PeterM » Tue Jul 05, 2011 3:44 pm
there is usually a removable small square stop which locates snugly inside the window channel fitted to the door glass, the block has a machine screw through its middle and once its in position you nip up the screw, you could probably drill a hole in the channel and fit a small nut and bolt with some washers that would do a similair job
Good chance it maybe lying loose in the door cavity
Experience is the name everyone gives to their mistakes
1963 OTS, Nearly
daverawle
Post by daverawle » Tue Jul 05, 2011 4:34 pm
PeterM wrote:there is usually a removable small square stop which locates snugly inside the window channel fitted to the door glass, the block has a machine screw through its middle and once its in position you nip up the screw, you could probably drill a hole in the channel and fit a small nut and bolt with some washers that would do a similair job
Mine doesn't have that, maybe it was different on some cars. The window travel is limited by a stop screw in the window regulator... see N24 of the service manual.
1963 OTS
lyons
#4 Door glass stop
Post by lyons » Wed Jul 06, 2011 11:47 am
Thanks for replies- will investigate further
