Buying a series 1 heater motor - Suppliers?
#1 Buying a series 1 heater motor - Suppliers?
Guys SNG no longer sell the Series 1 heater motor (although it is on their website) other than SCParts does anyone else sell the correct motor?
SC are expensive on this item so prefer to look around for a moment.
1964 FHC 4.2
Try Hutson's and M&C Wilkinson (the latter may also have a good s/h motor). Alternative is to do the Pontiac Fiero upgrade.
Clayton do the heater motors...think they supply the big boys
S1 4.2 Roadster in Resale Red
Mike Wilkinson had one so that'll do me...
Thanks for responding people.
Now to buy an ignition switch which SNG also no longer sell...
1964 FHC 4.2
Mike again? You could also try Richard Smith.
Odd this stuff is no longer stocked -wonder why? Cost, demand, lack of manufacturers?
Is there any reason why i cant use a later ignition switch?
The series 1.5/2 SNG switch looks pretty similar
1964 FHC 4.2
The later switch is much bigger so may not fit. Lots of s/h ones around though. Do you need the barrel lock or just the switch?
Edit: Actually there seems to be plenty of room for even the seven contact switch
Just the switch as mine appears to be permanently "on" but it made a horrible graunching sound when I turned the key so I think its dead.
Mike W had one for much less that I would have had to pay SC so that progresses the wiring a step nearer firing the engine.
1964 FHC 4.2
Staying with Heater motors - there was a discussion around how my motor was not original due to there being a lack of a flat plate that bolts the motor to the heater box.
The parts manual backs that up visually and as SNG no longer sell the motors I bought one from an alternative supplier it appears to be made by Clayton as suggested by Viper
The interesting thing is that the series 1 motor that was delivered could have the flat plate mounted as shown in the parts manual. However on the body there are also mounting plates half way up in the same place as the motor I had before.
....And the stepped plate that i had fitted perfectly. Pictures below...
Could my one have been a V12 motor body possibly?
The original and new motor next to each other
The original motor with mounting bracket
the new motor with mounting bracket
Naturally the motor spindle is bigger than the fan so the two dont go together :(
1964 FHC 4.2
