rear brakes
stevex75
#1 rear brakes
Post by stevex75 » Thu Dec 29, 2011 5:21 pm
I,m sure I,ve read somewhere of a modification with the rear brake calipers to have an extra bleed nipple in a more acessable place for ease of bleeding. Anyone done this?
Post by mgcjag » Thu Dec 29, 2011 6:25 pm
Hi Steve see attached link, found this from a search on the archives http://etypeuk.com/forum/viewtopic.php? ... nded+bleed Steve
vipergts
Post by vipergts » Thu Dec 29, 2011 7:16 pm
Can be seen here
S1 4.2 Roadster in Resale Red
vee12eman
Kiribati
Post by vee12eman » Thu Dec 29, 2011 11:33 pm
Hi Steve,
My version, sorry the focus isn't very good:
Hope this helps; the business end is just a double female ended connector to which I welded a short plate with a hole to bolt to the frame. If I did it again I would not place them so close to the end of the subframe (i.e. further from the wheels). If you have no welder, you could clamp them to the frame with a 'P' clip or similar.
Series III FHC
ChrisC
Post by ChrisC » Sat Dec 31, 2011 12:14 pm
I made something similar to Simons but to be honest I like the tidier version that Lee shows using the stainless feeds and may swap mine out for something similar.
1964 FHC 4.2
