new wiring harness
#1 new wiring harness
Morning team, I have a need to replace some or all of my wiring harness.
I have spoken with Autosparks and also see that the various Jag shops supply looms.
I do wonder if the other shops take to order, then have Autosparks and the like make up the looms ?
Q. who can you recommend for a good quality, well priced, timely delivery with good customer service.
1967, Series 1, 4.2, DHC, LHD
Thanks Tony
Thanks Tony
Tony in Devon
1967 Series 1, 4.2, OTS, RHD, Black.
#2 Re: new wiring harness
Autosparks unhesitatingly. I think that the others buy them from Autosparks in any event , but my experience of Autosparks has been very good
#3 Re: new wiring harness
Autosparks. I'm pleased with them. Deal with them direct. They sometimes supply the dash loom with the newer T5 bulb holder fittings instead of the original. Check this if you are going for concourse.
Also, if you want anything extra adding in - think of it now. You can get it added to the loom. Reverse lights, headlamp relay upgrade, warning buzzer, etc. etc.
-Mark
#4 Re: new wiring harness
Brilliant, thanks team.
Autosparks it is, they did quote me 10 weeks for an engine loom, best get it ordered without delay.
good tip about accessories and stuff
Tony in Devon
#5 Re: new wiring harness
Hi Tony.....you could ask Autosparks for a list of there suppliers and call around to see if any of them have one on the shelf
#6 Re: new wiring harness
Both SNGB and Manners use the AS looms, and are usually cheaper.
#7 Re: new wiring harness
Tony, do you need a LHD loom?
Angus 67 FHC 1E33656
61 OTS 875047
61 OTS 875047
#8 Re: new wiring harness
abowie wrote:Both SNGB and Manners use the AS looms, and are usually cheaper.
Tony in Devon
#9 Re: new wiring harness
engine bay and alt first, then i will convert to RHD in winter for the dash1954Etype wrote:Tony, do you need a LHD loom?
Tony in Devon
