#1 Electrical fault, heating up earth wire with no ignition on?
Posted: Thu May 31, 2012 9:27 pm
Recently used the car, all ok, parked up and left for a few weeks, went to start at the weekend and it came across as though it had a flat battery, engine turned and just died off, tested battery and tried another battery, batteries all good.
Car won't turn, checked all the wiring and found a few suspect earth cables so replaced. When I connect the battery an earth wire from the loom to the positive earth of the battery gets very hot very quickly, obviously I removed the battery quickly, solenoid only makes a click noise and won't start / turn engine.
Any ideas as I've not really touched anything? Earth to starter is good, earth from engine to body is good? All wiring seems ok, what I can see that is??!!
Any suggestions would be helpful as would like a run out over the bank holiday.
Many thanks Oliver
Many thanks Oliver
