Correct Routing of starter cable
Robert Scarlett
#1 Correct Routing of starter cable
Post by Robert Scarlett » Thu May 31, 2012 10:50 pm
Can anyone please tell me the correct routing of the cable between the solenoid and the starter motor on my 3.8 series one.
Robert.
1964 S1 3.8 FHC
kingzetts
Post by kingzetts » Fri Jun 01, 2012 7:39 pm
I believe the "correect" routing is along the lower frame rails to the picture frame in front of the engine, across the picture frame and along the other frame rail to the starter motor.
In my view this is unnecessarily long and therefore risks introducing voltage drop. When I restored my 3.8 I ran the cable across the back of the engine bay over the bellhousing - much shorter run. I also ran an earth cable directly back from the starter mounting bolts the same route to the battery negative post (my car is converted to negative earth) to ensure maximum starter performance.
John '62 S1 OTS (now sold)
Robert Scarlett
Post by Robert Scarlett » Fri Jun 01, 2012 10:58 pm
Thank you John for your reply it?s very much appreciated.
Looking at it logically I thought it ran along the bulkhead over the bell housing down to the starter but the new cable I have bought from Barratts is about 20? too long, that?s why I asked the question.
I think I will get the new cable cut and another terminal crimped on the end as I think your shorter cable route is better. And the earth lead is another Idea I will implement on my car.
Once again thanks for your help.
Robert.
1964 S1 3.8 FHC
Post by 1954Etype » Sat Jun 02, 2012 11:07 am
hmmmm. Not sure I agree with running it across the bellhousing - risk of chafing. The factory would have taken this short route if they thought it was better (definately cheaper).
kingzetts
Post by kingzetts » Sat Jun 02, 2012 3:34 pm
Fair point, Angus, but to clarify - the cable I ran does not lie on the bellhousing, it is fastened securely onto the bulkhead so is not exposed to chafing as the engine rocks on its mounts.
Post by 1954Etype » Sat Jun 02, 2012 5:18 pm
kingzetts wrote:Fair point, Angus, but to clarify - the cable I ran does not lie on the bellhousing, it is fastened securely onto the bulkhead so is not exposed to chafing as the engine rocks on its mounts.
John, there is absolutely no way I would challenge your engineering solutions! Just that not everyone might be aware of the potential pitfalls of modifying sometimes. If I'm not sure, I revert to standard. :D
Post by PeterCrespin » Sun Jun 03, 2012 4:59 am
Voltage drop is a real issue and is indeed related to cable length but it is also related to cable cross section. The voltage drop on such a hefty wire is negligible provided al connections are tight and the right cable is specified. Many cars, including Lots of Jags, have their battery in the boot and any issues are invariably to do with connections or dodgy earth studs rather than cable length.
Having said all that, I did exactly the same thing as John but that's because I had stuff to hand that suited and was insufficient for the standard run.
The warning about chaffing (or inadvertent pinching during jacking etc.) is very real. There are battery explosions or major arcing fires at issue once you start 'winging it' with the sort of current these thing carry.
Robert Scarlett
#8
Post by Robert Scarlett » Fri Jun 08, 2012 8:31 pm
John,
What thickness of wire did you use for your earth lead?
Robert.
1964 S1 3.8 FHC
kingzetts
Post by kingzetts » Sun Jun 10, 2012 8:24 pm
I just bought a couple of off-the-shelf braided earth cables (I think I got them from AES) so i'm afraid i can't tell you the precise sizes. It was pretty much belt-n-braces stuff as the standard earth calbres are also still all in place.
Robert Scarlett
#10
Post by Robert Scarlett » Mon Jun 11, 2012 11:27 pm
Thanks John.
1964 S1 3.8 FHC
