Door drain tube in Series 1FHC
david muir
Scotland
#1 Door drain tube in Series 1FHC
Post by david muir » Sun Jul 08, 2012 10:29 pm
Hi folks,
Anyone got any tricks/advice in refitting the plastic drain tubes which go from the top front corner of the doors down to the bottom of the door(the windows are still fitted but I hope there's a way!)?
thanks,
David
#2 Re: Door drain tube in Series 1FHC
Post by 1954Etype » Mon Jul 09, 2012 8:15 am
David can't help you with this one except to say persevere. I know it can definately be done.
Post by christopher storey » Mon Jul 09, 2012 10:17 am
The windows need to be up most of the way to enable you to get your hand behind the window frame at both top and bottom. It is a very very awkward job , not made easier by having to be done blind at the top , and small hands are a great help
Post by PeterCrespin » Mon Jul 09, 2012 2:08 pm
The way to do this kind of job is to feed a stiff wire down though the top drain and then feed your pipe up the same wire from the bottom. Pipes are always easier to press on than pull off, because they tend to swell under pressure and narrow under tension.
I must stop giving my stuff away for free :-) ;)
david muir
Scotland
#5 Drain tubes
Post by david muir » Mon Jul 09, 2012 5:24 pm
Thanks folks, , Least I know it can be done now! Will try again with the wire and will trim my hands with a grinder for easier access!
David
#6 Re: Drain tubes
Post by PeterCrespin » Mon Jul 09, 2012 6:12 pm
david muir wrote:Thanks folks, , Least I know it can be done now! Will try again with the wire and will trim my hands with a grinder for easier access!
David
Don't mess about with a grinder - takes too long. Bandsaw is best, unless your wife is good with a cleaver.
No, I said cleavER, not cleava... oh forget it :-)
david muir
Scotland
#7
Post by david muir » Wed Dec 05, 2012 1:59 am
Okay folks,
Have had a determined 'go' at fitting driver's side tube.......no joy! Tried feeding stiif wire down from top but wire disappears behind hinge assembly and does not reappear until at bottom of door.
Just doesn't seem to be any space to refit these with door and internals fitted........anybody with any more tips?
thanks,
David
Post by 1954Etype » Wed Dec 05, 2012 11:48 am
David
speak to Andy at Hutsons. They definately fitted the tube to my doors after they had been skinned.
vacbag
#9 Drain Tubes.
Post by vacbag » Wed Dec 05, 2012 2:36 pm
Question o wise ones.
In my S2 OTS the drain tubes end just above the bottom of the doors and water then presumable exits through the two drain slits in the bottom of the doors, Is this correct?
The reason i ask is because when it rains the drain slits are often overcome and water builds up inside the doors and leaks into the cockpit.
Steve.
Steve. Series 2 OTS.
ChrisC
Post by ChrisC » Wed Dec 05, 2012 4:28 pm
shouldn't be that much water getting into the doors to be honest. but yes your water flow theory is correct.
The slits are quite large - a couple of inches or so which should let out quite a lot of water... is the sill rubber blocking them preventing egress?
1964 FHC 4.2
Post by Heuer » Wed Dec 05, 2012 4:39 pm
Originally the sill rubbers had two cutouts which matched the drains although it seems the modern replacements do not have them. Even if they do the ruibbers can be mounted wrong way round which prevents then from working as designed.
http://etypeuk.com/forum/viewtopic.php? ... oor+drains
