Horn issue
Mad River
#1 Horn issue
Post by Mad River » Thu Jul 12, 2012 3:04 am
Howdy gents! Another question about our Jag. When we picked it up on Monday, the horn was working fine. Now the horn is silent. The relay appears to be working, since I can hear it click whenever I push the horn button. Any wisdom would be much appreciated! Thanks!
1965 E-Type FHC (two-seater) (LHD), 1959 Austin Healey 3000 BT7, 1968 Triumph TR-250, 1964 Sunbeam Tiger, 1971 Triumph TR-6, 1954 Willys M38A1 Jeep
stef
Post by stef » Thu Jul 12, 2012 3:23 am
Poor connection ?
I fixed the light in my dials and they work fine during the day. At night they seem to go on strike
Clean all connections and use contact grease is a good start
Stefan
Sydney Australia
1963 3.8 OTS
NickJ
#3 Horn Issue
Post by NickJ » Thu Jul 12, 2012 8:53 am
Exactly the same happened to me the other day. If you are getting the relay clicking then it should be simple. Pull off the connecting plug that takes the wires into the electrical units held in the bonnet and either clean the contacts or simply jiggle them around. If that fails then see if you have any bullet connectors between the horns and the plug and do the same.
Nick James 1962 FHC
ChrisC
Post by ChrisC » Thu Jul 12, 2012 11:12 am
There is also a fuse for the horn 50 amp from memory. The relay will still operate with a blown fuse so I would check that first.
1964 FHC 4.2
Mad River
Post by Mad River » Thu Jul 12, 2012 6:35 pm
Thanks! Looks like a job for my emory board and/or box of fuses.
This has been interesting. First time we've purchased a concours car, but it seems to suffer from many of the same challenges as our drivers! Nature of the beast, I guess. Connections get dirty, Lucas gremlins come a'creeping, etc.
