Headlight dipper switch
#1 Headlight dipper switch
I just discovered my original headlight dipper switch has a lose conta t on a couple of the spades on the back. Probably caused by over zealous pulling off of the spade terminals. Past experience of this problem leads me to believe it will not work properly and short around the lose rivet. So question is has anyone bought a new made switch and if so how does it match up to the original?
Mark Gordon
I bought one from XK's Unlimited in the U.S. a few years ago. The contacts on the back didn't match up with the original, but a few minutes with an ohmmeter sorted out which wires went where and then it otherwise fit and worked perfectly.
#3 Re: Headlight dipper switch
Can't you just scratch back to shiny metal and tap the rivet a little tighter then solder for better electrical contact?andrewh wrote:I just discovered my original headlight dipper switch has a lose conta t on a couple of the spades on the back. Probably caused by over zealous pulling off of the spade terminals?
SNGB version looks reasonably accurate:
thanks guys, as always. I have ordered an SNGB as its only ?12 or so, and will try to see whether I can re rivet the original tab but there is plastic under neath it, so may prove tricky perhaps a dab of solder will suffice, there again, bound to fail when I least need it! hope the SNGB one will be ok. thanks
Ok so I just carried out a full wiring check and have only one problem in that my cigarette lighter has a short. It appears that the contacts at the bottom which the actual removable part of the cigar lighter contacts with when You push it in move out to contact the outer shell and cause a short. Can buy a new cigar unit I guess but just wondered whether anyone had experienced the same problem and sorted a fix? I tried to bend the contact away from the side but as soon as you push the centre in you get the same problem. Am I missing an insulation washer perhaps?
