Electrical fault
rah59
#1 Electrical fault
Post by rah59 » Sat Aug 04, 2012 7:14 pm
Hi all, hope someone can help
Just bought a 3.8 fhc, day one have driven about 30 miles, ammeter indicated charge most of the time, left car for a couple of hours and horn went off (ignition off). Isolated battery and checked voltage (12.6V). Havent got a wiring diagram so unsure what it can be. Dont think there is an alarm or imobiliser
thanks
Post by Heuer » Sat Aug 04, 2012 8:29 pm
Wiring diagrams here: http://www.etypeuk.com/forum/viewtopic.php?t=1664
No idea about your fault condition because it is not typical of an E-Type. Keep us informed :wink:
rah59
Post by rah59 » Sat Aug 04, 2012 10:14 pm
Thanks David
disconnected horn at multi pin plug arrangement, after looking at wiring diagram the feed to the horn relay appears unswitched (not ignition switch controlled) so i suspect the relay contacts are closed, will check the control circuit and horn contacts with volt meter.
Many thanks for pointing me in right direction
Robin
rah59
#4
Post by rah59 » Tue Aug 07, 2012 9:43 pm
Hi all
have just got back home after a few days away and had a look at the wiring in relation the s1 dia.
The horn relay has 4 spades W1 and 2 serve the coil circuit with C1 and 2 being the switch circuit. C2 is the feed from the fuse, this is via a brown cable with a purple tracer on the dia, my car appears to have had a new loom at some point and the cable is just brown. The cable from C1 is purple with yellow tracer as the diagram.
Terminal C1 has a double spade (switch side) onto this was connected another brown cable this as well as the other brown show +12V
does any one have any idea what this extra brown is?
both brown cables enter the loom and route toward the dash.
Given the connection of the 2nd brown this must be switched as the horn didnt go of previously but has now become live.
fs383
#5 Looking for a wiring diagram
Post by fs383 » Sat Jan 12, 2013 6:23 pm
Hi to all
I am trying to open the link to the wiring diagram http://etypeuk.com/forum/viewtopic.php?t=1664 but unfortunately the link no longer works.
I am in the process to fit a new wiring loom to a 1967 E Type LHD and the old loom is of no help to me as it was cut up by the PO.
Any one with a good diagram that is willing to share??
Dave K
#6 Re: Looking for a wiring diagram
Post by Dave K » Sat Jan 12, 2013 7:14 pm
fs383 wrote:Hi to all
Coventry auto components sell a plasticised colour coded wiring diagram. It is a must have for any owner.
Don't know their website address offhand but shouldn't be hard to google.
Post by Heuer » Sat Jan 12, 2013 7:34 pm
Try these:
S1 4.2 wiring diagram: http://dl.dropbox.com/u/8496016/E-Type%2042wiring.pdf
S1 4.2 Colour Wiring Diagram (by Bill Molloy): http://dl.dropbox.com/u/8496016/S1%20wi ... Colour.jpg
S1.5 colour wiring diagram: http://dl.dropbox.com/u/8496016/XKE%20S ... iagram.bmp
vikla
#8 Coventry auto
Post by vikla » Sat Jan 12, 2013 8:27 pm
Coventry Auto sell their booklets on Ebay covering most old Jags
This is the 4.2 one - http://www.ebay.co.uk/itm/E-Type-Series ... 58995fd4ec
There is also a 3.8 version
It is not plasticised and in the 4.2 version the diagram of the fuse box layout is incorrect for my 1966 car. Overall though I think it is worth having.
S1 4.2 FHC 1966
fs383
#9
Post by fs383 » Sat Jan 12, 2013 8:31 pm
Thank you for that David, will try to find my way around this
Florian
Dave K
Post by Dave K » Sat Jan 12, 2013 11:20 pm
Regarding your horn fault I would check the steering column. Inside there there is a spring that rests against a brass collar. Sometimes this spring can come out and wrap itself around the inside causing a short to the horn relay and sound your horn.
If the spring is at fault then it will likely be wrecked and the usuals don't sell them. You can remove the spring from a Biro, it fits perfectly and should hopefully solve your problem.
rah59
#11
Post by rah59 » Sun Jan 13, 2013 10:19 am
Hi Dave
the horn push assembly provides the earth connection, this is working ok. I appear to have an additional cable fitted to the switched side of the relay which is permanently live, this i have traced as the fault. I have been unable to trace the other end or source of this cable so have disconnected it, fault cured! Sort of. This cable is not shown on any diagram i have have seen. After disconnecting it, all other electrical systems still work, so at a bit of a loss, speaking to the previous owner he has confirmed the car isnt fitted with an alarm so that a blind alley.
Thanks for your help
robin
