Rotational noise from rear?
thegfb
#1 Rotational noise from rear?
Post by thegfb » Thu Aug 16, 2012 10:45 am
A rotational 'click' noise has appeared at the rear of my S1 FHC 3.8. It only manifests itself after 15 miles or more of motorway or fairly high speed A road driving. It doesn't seem to be brake linked as it doesn't disappear if I touch the brake pedal. The car runs on standard size wheels with Avon Turbospeed tyres so I don't think it's a tyre rubbing issue though as I don't have a car lift I can only jack the car and, of course, the wheels drop so I can't check if there's any rubbing. Anyway it doesn't seem to related in any way to whether the suspension's compressed or not as it is at it's most audible if I sit in the car and roll at low speed and listen with the car door open.
Any ideas?
Post by christopher storey » Thu Aug 16, 2012 1:00 pm
It might be advisable to check your wheel spokes . Run the wooden handle of a fairly substantial screwdriver over them, and listen for any which sound dull. Also have a look to see that none are missing !
thegfb
Post by thegfb » Thu Aug 16, 2012 2:13 pm
I replaced the wheels fairly recently with new painted items from MWS (think they look better on a very early car) but, nonetheless, I will check as per Christopher's suggestion (thank you very much for your response).
If it's not that might it be diff linked? Or perhaps one of the UJs?
I know it's almost impossible to be definitive without seeing the car but any further hints which might take me in the right direction would be much appreciated.
Post by Heuer » Thu Aug 16, 2012 2:36 pm
Have you put limited diff additive into the rear axle or used the correct fluid with additive?
Post by christopher storey » Thu Aug 16, 2012 4:25 pm
With new wheels my suggestion of loose spokes seems unlikely . Is it once per wheel rotation, or once per propshaft rotation i.e. about 3.3 clicks per wheel rotation ( assuming you have the 3.31 final drive ) ? And have you checked those pestilential UJ covers at the outer end of the driveshafts - they are forever moving and touching something as they rotate - I abandoned mine as a result
