Fan switch
peters3103
#1 Fan switch
Post by peters3103 » Thu Jan 30, 2020 10:20 am
Hello gents,
I bought an 80 deg on - 70 off S.U fan switch from Burlen to replace my knackered original otter. I note that it is longer and fouls the inlet pipe on the inside of the header tank. I’ve sorted it by judiciously filing some of the pipe away through the switch hole but wondered if others have had this problem. It’s one of two switches listed by S.U for the E Type, the other being a 90 on - 80 off. Presumably the same length. I’ll be using this to run my Coolcat fan. I also have the Coolcat switch but it comes on at 85 deg. Thought that it may be too hot.
Cheers,
61 E-Type FHC Opalescent Golden Sand - now sold 😕
