Stone guard space
#1 Stone guard space
After getting my car home I realized no stone guard! I think it's because it won't fit as I have a Kenlow fan mounted directly in front of rad .
Question is since its impossible to measure when bonnet its closed does anyone know how close the stone guard would be to front of the rad when all is shut?
Gary
63 fhc
887465
Gary
63 fhc
887465
The stone guard fits quite snugly to the radiator. Certainly not much farther forward than 1 inch / 25mm, so it is the fan that is the problem
#3 Re: Stone guard space
Gary
you shouldn't have a fan in front of the rad as it will restrict airflow. I would recommend removing it and replacing the original with a coolcat fan.
Angus 67 FHC 1E33656
61 OTS 875047
61 OTS 875047
I think Ken Verity might have some. Failing that, go to www.coolcatcorp.com.
61 OTS 875047
61 OTS 875047
#7 Re: Stone guard space
I have a spare stone guard in stainless steel. I've had it knocking around for ages.The mounting holes aren't drilled into it though.the doc wrote:After getting my car home I realized no stone guard! I think it's because it won't fit as I have a Kenlow fan mounted directly in front of rad .
Gary
63 fhc
887465
#8 Re: Stone guard space
No you don't Dave ;-). We are talking about the grill that fits on the bonnet in front of the rad....
61 OTS 875047
61 OTS 875047
Dave, Angus might need that shortly for my OTS.
