Can anyone tell me how the aluminium stone guard BD27427 is fitted?
At the sill side, is it fitted on top of the battery support, or is it sandwiched between the sill and the battery support?
At the back, does the edge sit under the floor or should it sit on the kick panel bottom edge?
Thanks,
Left hand undershild stoneguard fitting
#1 Left hand undershild stoneguard fitting
#2 Re: Left hand undershild stoneguard fitting
Hi Paul
At the side, it should be sandwiched between the sill and the battery support. At the back it sits under the floor.
Angus will confirm this cos I got it wrong first time and he put me straight....
Jeremy
1967 S1 4.2 FHC
1967 S1 4.2 FHC
#3 Re: Left hand undershild stoneguard fitting
Thanks Jeremy; much appreciated
