#1 Differential problem?
Posted: Wed May 22, 2013 3:59 pm
by MichaelHiggins
I have just installed the IRS , all went smoothly but when I tried to turn the car one side jammed and just skidded , I didn't get the diff checked as it was running smoothly and there were no obvious sign's of chipped teeth etc. when I inspected inside , it runs nice and smooth just going forwards and backwards!!! am I correct in thinking its all got to come out and the diff overhauled?
Posted: Wed May 22, 2013 7:43 pm
by 1954Etype
Not sure you have explained it well but, if I have understood, you raised the car on one side and put the car in gear with the engine running?
On a normal diff, one wheel will freewheeling, a LSD will provide drive to the wheel on the ground and run it off the jack.
Posted: Wed May 22, 2013 10:28 pm
Not sure what work you've done to the IRS prior to reinstalling it, but it could be a brake/handbrake issue.
