Upper wishbone ball joints
andrewh
#1 Upper wishbone ball joints
Post by andrewh » Thu Jun 06, 2013 5:55 pm
I am just about to send off the front wishbones and fulcrum shafts for plating and wondered what most of you have done about top ball joints. I hear they need shimming up fairly regularly and the cup cannot be pressed out. If I plate the wishbones the cup would presumably be plated, not good, so what do you all do?
1962 3.8 Series One FHC
Post by Heuer » Thu Jun 06, 2013 5:58 pm
Dave K
Post by Dave K » Thu Jun 06, 2013 6:08 pm
E-Type fabs will also recondition the top ball joints as far as I know.
chrisvine
Post by chrisvine » Thu Jun 06, 2013 6:19 pm
Andrew,
I've just installed the CMC ball joints but I've only just started on the actual rebuild so a way off driving with them fitted.
I made the mistake of getting a kit and trying to get the wishbones machined locally. The instructions suggest annealing first. Unless you know a good machinist, I'd recommend getting complete units from CMC.
Chris
1969 S2 OTS, Elise S1
1954Etype
Post by 1954Etype » Thu Jun 06, 2013 7:16 pm
I fitted the CMC units (machined them locally) and also fitted to a customer car. No problems and would recommend them.
Angus 67 FHC 1E33656
61 OTS 875047
wol916
Post by wol916 » Thu Jun 06, 2013 7:58 pm
Uryk at etype fabs machined mine also got them plated and fitted the new maintenance free joints all for a very reasonable price, the man is a star :lol:
Warren
S1 FHC 4.2 OSB
andrewh
Post by andrewh » Thu Jun 06, 2013 9:34 pm
all good advice thanks. The only thing that is troubling me , and I am easily troubled , is matching the plating on the CMC parts with the rest of my front suspension. Thoughts?
Post by PeterCrespin » Thu Jun 06, 2013 9:58 pm
andrewh wrote:The only thing that is troubling me , and I am easily troubled , is matching the plating on the CMC parts with the rest of my front suspension. Thoughts?
Drive the car sufficiently that the resultant oad dust and weathering equalise any tiny difference.
This strategy has other benefits besides masking any plating anomalies.....
andrewh
Post by andrewh » Thu Jun 06, 2013 10:05 pm
Yes but no but yes! It has to be right when I fit it up or it's not right.
Post by Heuer » Thu Jun 06, 2013 10:50 pm
Ask CMC what plating they use? Alternatively buy t,he kit and ha ve your wishbones machined and then plated.
But I think Pete has it nailed - unless you are building a 'no go show-boat' does the different plating tint really matter? Besides the early cars had a random mix of black and cadmium plated A struts.
Post by abowie » Thu Jun 06, 2013 11:27 pm
I bought a set of the CMC units from Barratts. They're zinc plated which matches the rest of my car. Although Jaguar used cad plating originally, this is hard to come by these days.
I looked at getting my old wishbones machined; turned out to be more economical to just buy the whole unit from Barratts.
andrewh
Post by andrewh » Fri Jun 07, 2013 5:50 am
I think that the difference between the various plating coatings is large. If you saw a dull chrome next to a yellow zinc or even a bright zinc and then a dull zinc and cad, you would really notice the difference. I do use my cars but thats not the issue. It would annoy the hell out of me if it was all different on the day it was finished.
Basically a little thought should be able to get it all plated the same. I have dropped CMC a mail and will see what he says and report back . thanks chaps
