3.8 FHC wiper motor and details
andrewh
#1 3.8 FHC wiper motor and details
Post by andrewh » Sat Jun 08, 2013 10:26 pm
Guys. I am in need of the link arm that connect from the back of the motor to the rack or at least the rotating crank assembly in the end. Is it available separately I cannot find a part number. Plus can anyone let me a photo or two of how the motor fits back on to the plate? Are they some rubber spacers etc? Thanks.
1962 3.8 Series One FHC
tinworm
Post by tinworm » Sun Jun 09, 2013 6:50 am
available from RM&J Smith
andrewh
Post by andrewh » Sun Jun 09, 2013 6:53 am
ok thanks for that. I will give them a call on monday
cheers
Andrew
andrewh
Post by andrewh » Tue Jun 11, 2013 8:57 pm
can anyone please advise on the bolts, washer, nuts , rubber bushes order holding on the wiper motor to the mounting plate ? I have 8 washers which I believe are for this, fitting either side of the rubber bush, four of the washers have small nicks in them?
andrewh
Post by andrewh » Sun Jun 23, 2013 10:35 am
just fitting the wiper rack and spindles with covers but the new rubber bought from SNG seem too thick to let you get the nut started. Has anyone else found this? I cannot find my original rubber gaskets but I am sure they should be thinner. the replacements are about 1/8 inch thick and pretty hard so will not compress very much.
