Cleaning up wiper motor castings
Pete Gant
#1 Cleaning up wiper motor castings
Post by Pete Gant » Sat Jun 22, 2013 1:44 am
How do you clean up the aluminium- die cast parts on the window wiper motor to look like new?
Pete Gant NZ 1966 E Roadster
andrewh
Post by andrewh » Sat Jun 22, 2013 5:42 am
Mine was sent away for refurbishment. However I would suggest ultrasonic cleaner.
Edit. Or vapour blasting. I have a friend who vapour blasts his Japanese motorcycle carburettors and they come back like new.
1962 3.8 Series One FHC
Post by abowie » Sat Jun 22, 2013 6:04 am
Spooky. I have just come in from doing this in the shed.
For the end piece with the dome on it I gently used the wire wheel on my 6" bench grinder. It came up really well.
The other casting that contains the big gear cleaned up adequately with kero and a nylon brush.
The aluminium plate I cleaned with kero and a brillo pad. It wasn't too badly scratched but I would have polished it with a buff if it had been. I used the wire wheel on the motor casing and the mounting plate and painted them with hammertone.
I replaced the wires too. As I am converting my car from LHD to RHD I also swapped the blue and red wires over.
See http://www.projectetype.com/index.php/the-blog
