Radio/Ipod ........new interference!
david muir
Topic author - Posts: 255
#1 Radio/Ipod ........new interference!
Folks,
Have a 60's Motorola converted to VHF with an Ipod lead. Last time I used it [last year!] everything worked perfectly, now there's a steady ,regular ticking coming through the speakers(no music).
Only things done over winter were:- distributor rebuilt, LED instrument illumination and voltmeter fitment.............what's changed?
David
David
Is this with the engine going or with the engine switched off but ignition on?
david muir
SU fuel pump?
The steady regular ticking is probably RF interference every time the points open on the instrument voltage regulator. I assume the only reason you're hearing it is because everything else is silent due to the amp having no input signal.
Have you dislodged the aerial and/or checked every signal source. For correct function? If all wavelengths and the iPhone jack are dud despite power being on and a correct antenna attached then assuming the volume is turned up it sounds like a tuner issue.
david muir
#6 iPod/iPhone/radio
Folks,
maybe mislead you!.........problem only exists trying to play music from an iPhone, the iPod works fine.........strange!
This is with the engine and ignition off.
Buy an Android phone?
I have just fitted the greatest bit of kit to another classic and negated the need for an expensive FM conversion of an old AM radio. As an aside I had a Radiomobile converted some years ago, at quite a price and to be honest, its not good. Its very difficult to obtain a clear signal and as there is no lock on as with modern digital radios you have to continually retune the set to keep the program. All in all a bit of a bore plus it only gets about 4 programs in total.
However, the new bit of kit , I cannot recall what its called right now but will report back if someone doesn't beat me to the name, comprises of a very small screen and a very small control pad. They work on Blue tooth and if you have an ipod you can play all your music and use a radio app to listen through you speakers. Frankly guys, if you hide the unit above your knee or somewhere similar its a superb solution to the perennial radio in an old car problem. I will try to photograph my installation tomorrow and post it up.
I do however want to fit an old smart 5 button Radiomobile or Motorola for aesthetics so if anyone has a spare one to sell please pm me.
Would be really interested in your experience with device you talk of. I too have tried the original radio upgrade route and been disappointed with the result so keen to hear how things turn out. Please post details?
Chris
Chris
Have a look here http://etypeuk.com/forum/viewtopic.php?t=163 and here http://etypeuk.com/forum/viewtopic.php?t=2540
And for speakers see here: http://etypeuk.com/forum/viewtopic.php? ... er+wadding
