IRS hub nut
#1 IRS hub nut
Can someone kindly let me know what size the hub nuts are on the IRS? My largest socket is 1" and it's too small.
62 3.8 FHC
91 Porsche 928GT
62 3.8 FHC
91 Porsche 928GT
#2
I think, but am not certain, that they are a 3/4 UNC nut and require a 1 1/8" AF socket . I have checked with the part numbers but this is equivocal because it appears to show a 9/16 nut which would require a 7/8 spanner, which plainly is not the case on your car, and which does not agree with my recollection. Your best bet is to measure the nut with a caliper
Thanks Christopher, much appreciated. I can't easily measure the nut due to how far it is set into the hub :-(
62 3.8 FHC
91 Porsche 928GT
62 3.8 FHC
91 Porsche 928GT
I've tried to measure it and it looks like 1 and 5/16".
Can anyone else confirm this?
Thanks.
Thanks.
62 3.8 FHC
91 Porsche 928GT
62 3.8 FHC
91 Porsche 928GT
Hi Simon,
If you mean the castellated nut which holds the splined hub on, I just checked and Chris's recollection is correct - it takes 1-1/8" socket.
Cheers,
Neil
Cheers,
Neil
#6
Simon : no, it is definitely not 1 5/16 because this is the size of the socket which fits the front pulley nut which is the biggest on the car ! I have a mini driveshaft nut socket ( which used to be available in all factors ) which fits the pulley nut
Christopher/Neil,
Really appreciate your replies - looks like I need to buy two new sockets then, a 1 and 1/8" for the castelated hub nuts and a 1 and 5/16" for the crank pulley :-)
Thanks.
Thanks.
62 3.8 FHC
91 Porsche 928GT
62 3.8 FHC
91 Porsche 928GT
#8
Simon : I hope I have not misled you about the pulley nut socket size - it could be 1.5 inch !! Again, best to measure it across the flats and use the on-line size converters to see what you need
Hub nut 1 1/8.
Crank nut 1 5/16.
Crank nut 1 5/16.
Thanks all for the help, really appreciated :-)
Now, where is that impact wrench...........
62 3.8 FHC
91 Porsche 928GT
62 3.8 FHC
91 Porsche 928GT
