Differential
Simonpfhc
#1 Differential
Post by Simonpfhc » Fri Jul 05, 2013 8:30 pm
Whilst preparing to remove the IRS assembly, i noticed something strange - the diff seems to be permently locked ie both wheels freely rotate backwards and forwards together, but you cannot turn one wheel if the other is held. Am I seeing the effects of the PowerLoc assembly or is there (as I suspect) a fault with the diff assembly?
Cheers.
62 3.8 FHC
91 Porsche 928GT
Dave K
#2 Re: Differential
Post by Dave K » Fri Jul 05, 2013 9:18 pm
Simon,
You have a powr lock diff.
Simonpfhc
Post by Simonpfhc » Sat Jul 06, 2013 6:49 am
So the behaviour I am seeing is normal with a Power Loc diff? I need to read up about how this diff works in compariosn to a normal LSD then as it must be different.
Thanks.
62 3.8 FHC
91 Porsche 928GT
