#1 location of cooling fan earth and relay
Posted: Wed Aug 21, 2013 2:20 pm
My car passed its MOT this morning. Unfortunately during the test the cooling fan failed resulting in lots of steam and coolant all over the place.
Back home I checked the dashboard fuse was OK, then connected +12V directly to the fan's wiring connector - nothing. Checked out the negative side of the fan to see if it was getting a good earth but it wasn't. So wired both sides of the fan directly to the battery and it worked fine. Therefore I guess the problem is a bad or broken earth somewhere. The fan wiring disappears into the main loom feeding the bonnet connector and the horns.
So the question is does anyone know where the chassis or ground connection is made off to from the fan motor's negative side?
Whilst I was at it I also tried to find the fan relay (a Lucas 6RA?) .
I see in another post - 'The fan relay fits on the outside of the header tank support on the drivers side (RHD)'. Well I cannot find it. Looked in the Jaguar Service Manual and on page P.X.s.27, fig 22 there is a drawing of it, but it doesn't look like a S1 4.2 to me, maybe an S2.
The Otter switch wiring goes into a main loom near the distributor and together with the fan wiring should end up at the relay wherever it is.
Any other views on locating the fan relay?
Thanks in advance for any assistance.
