Dash fixing info please
andrewh
#1 Dash fixing info please
Post by andrewh » Sun Sep 08, 2013 5:07 pm
Can any kind soul tell me whether there is a fixing on the very bottom of the left and right dash panels. If you look at the photo you will see a hole in the black vinyl covered part just below the guide bracket for the swing down centre dash panel. I don't recall what was in this hole and if there is a fixing can some one tell me what it should be please. It would be very close to fouling the alloy dash panel as it swings up Wonder whether its left empty?
1962 3.8 Series One FHC
Post by abowie » Sun Sep 08, 2013 9:35 pm
I could be wrong but I wonder if that hole allows access to the bolt that holds the choke mechanism together. Tightening it stiffens up the mechanism. I haven't got that far yet as I've only just put my instrument panel in..
andrewh
Post by andrewh » Tue Sep 10, 2013 7:01 pm
I think you are looking at the bg hole above the angle bracket not the hole below, tricky to see. It must have fixings in it . Anyone?
1954Etype
Post by 1954Etype » Tue Sep 10, 2013 8:25 pm
I think there is a 3\16 screw there.. See if there is a captive nut on the other side of the hole.
Angus 67 FHC 1E33656
61 OTS 875047
vipergts
Post by vipergts » Tue Sep 10, 2013 9:25 pm
Screw I think Andrew
S1 4.2 Roadster in Resale Red
andrewh
Post by andrewh » Sat Sep 14, 2013 12:03 pm
Thanks guys. There is no captive nut so I will fit a small nut and bolt should clear the dash centre Thanks chaps
