Series 1 2+2 core plugs and head colour
Spark
#1 Series 1 2+2 core plugs and head colour
Post by Spark » Sat Nov 23, 2013 10:10 am
Hi rebuilding a series 1 2+2 4.2 engine
1967
Should I leave the core plug olour black or paint them gold
Should the head be painted or left un painted
If gold what's the colour code
Any help please
tim wood
Post by tim wood » Sat Nov 23, 2013 10:19 am
Mine is a 1966 version and when I researched found that originally the head was meant to be unpainted. I prefer gold so that is what I did. ,
I think the original, now unobtainable, colour is Bradite old gold.
Lots of discussion here if you search the archives.
Tim
Spark
Post by Spark » Sat Nov 23, 2013 11:20 am
Im with you it looks better
phil
Durango2k
Post by Durango2k » Sat Nov 23, 2013 5:15 pm
I am restoring an UNTOUCHED S1 2+2, and the head WAS GOLDEN.
I got it CO2- ice- blasted, looks great now, but when the dirt went away we found lots of golden colour flakes so this is how it left Coventry in March 1966 for sure.
Will go back to gold on mine as well, I heard SNG sell the correct stuff - I have to buy it, once I get up to do the head.
Then, regarding the core plugs - anyone ?
On my engine they are all rusty. I have to have a look for their paint- gold looks gorgeous.
Carsten
Post by Heuer » Sat Nov 23, 2013 6:37 pm
All the S1 4.2 engines with smooth cam covers had Old Gold painted heads. The S2 heads were not painted and therefore silver in colour. You can buy gold engine or brake paint off eBay which is a good match.
Durango2k
Post by Durango2k » Sat Nov 23, 2013 8:41 pm
Is there a paint scheme somwhere ?
I mean they did not paint the complete head, only parts of it.
Where are the "borders" ?
I could not recognize them on mine, too much was gone...
Carsten
Post by Heuer » Sun Nov 24, 2013 10:34 am
The heads are painted everywhere apart from the mating surfaces of the block, manifolds etc. Basically any part of the head you can see when it is on the car is painted gold. I used this: http://tinyurl.com/odab6yn if you are going to brush it on or http://tinyurl.com/pme4dpt if you want to spray it. The casting is so rough you won't see any brush marks.
There is a list of colours used on the car here: http://www.etypeuk.com/forum/viewtopic.php?t=951
1954Etype
Post by 1954Etype » Sun Nov 24, 2013 10:43 am
Heuer wrote:All the S1 4.2 engines with smooth cam covers had Old Gold painted heads. The S2 heads were not painted and therefore silver in colour. You can buy gold engine or brake paint off eBay which is a good match.
Going to have to disagree here David. It depends on the engine number. The later S1 4.2 cars had silver heads with smooth cam covers. For example 1E15533 is a 67 OTS with that combo.
Angus 67 FHC 1E33656
61 OTS 875047
Pim
Netherlands
#9
Post by Pim » Sun Nov 24, 2013 10:52 am
Heuer wrote:The heads are painted everywhere apart from the mating surfaces of the block, manifolds etc. Basically any part of the head you can see when it is on the car is painted gold.
Well, what about the front part and sides of the front part of the head where the timing gear sits, that is polished, not painted yes?
Apart from that, I have a late series 1 (Febr 1967) and painted the head, later found out that it has to be unpainted, I think it was in Anders Clausagers book.
Pim van der Schaaf
1E34261
1A33630BW
Post by PeterCrespin » Sun Nov 24, 2013 4:57 pm
Only in the valley. The front and sides are unpainted.
Pim
Netherlands
#11
Post by Pim » Sun Nov 24, 2013 5:03 pm
Weren't the sides also painted, just above the intake and exhaust manifolds, also the rear of the head where the blanking plate is and the tach generator, and the area below the crank breather?
Pim van der Schaaf
1E34261
1A33630BW
Post by PeterCrespin » Sun Nov 24, 2013 6:38 pm
The rear yes, I think of that as being valley run-off :-)
I used to think the sides too Pim and have done mine that way. I later read somewhere (in the last year or so?) that it wasn't correct, same as the rough bit below the breather which I have also painted on previous heads. For me to change my mind it must have been an authoritative book or something. Maybe that book was wrong and it's true the front and sides were painted after all?
Pim
Netherlands
#13
Post by Pim » Sun Nov 24, 2013 7:20 pm
The E-type buyers' guide from our marque expert?
Pim van der Schaaf
1E34261
1A33630BW
Post by Heuer » Sun Nov 24, 2013 7:34 pm
No, the JCNA S1 Judge's Guide: http://www.jcna.com/library/tech/e-type1.pdf It says aluminium heads from 1966
"Cylinder Head Colour - Gold colored to silver- At this point in time ,6-2013, we cannot state positively whether any E-Type titled as a 1967 had a gold painted head. "
Pim
Netherlands
#15
Post by Pim » Sun Nov 24, 2013 7:45 pm
No David, this last post is about the area to be painted, not whether to paint or not ...
Pim van der Schaaf
1E34261
1A33630BW
Post by Heuer » Sun Nov 24, 2013 7:53 pm
Pim
Netherlands
#17
Post by Pim » Sun Nov 24, 2013 8:23 pm
Yes, that is how I did mine, all rough areas painted although the polished areas on mine do not look as good as these.
Just looked it up in Clausager's book, but it does not state which areas were painted, just that somewhere in late 1966 the gold paint on the head was dropped.
Pim van der Schaaf
1E34261
1A33630BW
Mark Gordon
Post by Mark Gordon » Mon Nov 25, 2013 12:29 pm
Mine, 1E-14988, March 1967, came with a silver head.
Post by Heuer » Mon Nov 25, 2013 12:40 pm
You can thank Mr Arthur Whittaker, Jaguar's chief buyer and personally tutored by Sir William, who looked for every opportunity to cut costs and needlessly painting a cylinder head was one of them. Over painting the Glyptol red differential casings with gloss black being another.
Pim
Netherlands
#20
Post by Pim » Mon Nov 25, 2013 1:06 pm
Scrooge was an amateur?
Pim van der Schaaf
1E34261
1A33630BW
