A very tricky repair
PaulColeman
Topic author - Posts: 247
#1 A very tricky repair
I have a 1965 FHC which has been bodged by the previous owner and I have to tackle a very tricky repair in the near future. The 'B' pillars are the supports for the rear side windows and are basically a bit of chromed channel with a right angled bracket on either end with a pair of fixing holes. There are bolts which go through those holes and fix into captive nuts inside the body. The previous owner has drilled a huge hole in mine (i.e. the captive nut) so there is no thread to screw the bolts into. Has anybody managed to repair these?
I could do what he did and put a nut on the back of the bolts but it's a difficult job to get at it.
Also, one of the uprights has a split by the fixing hole. Any idea how to repair that as it's very thin at that point.
Paul.
Paul.
I can't quite picture where the particular captive nut is, but can you Helicoil the hole drilled in it?
PaulColeman
Here is a picture of the ones I'm talking about...
I'd really like to get that captive plate out and replace it (need to do the same on both sides).
Paul.
Paul.
Paul - it is not an ideal solution, but you could araldite two appropriate size and thread nuts to the underside of the captive plate to restore it to its original function
If you're at that stage in the body shell restoration just bite the bullet and cut the plate out, replace it and reweld the panel.
PaulColeman
That's the problem, I'm not sure how to get it out. I could cut a rectangle out above it but that looks quite tricky.
Paul.
Paul.
Paul,
Do it once and do it right it's the only way. A couple of cuts with a 4" angle grinder fitted with a 1mm thick cutting disc should keep it neat. If you have a compressor, a die grinder with a 40mm x 1mm disc would be ideal.
The other option would be to use a Dremel and about 40 cutting discs.
I have no idea what is in that section, I've never looked closely at a FHC so the above might be complete b******.
You are the custodian of this E-Type so do the job properly even if it involves cutting/extra expense. If you don't it will gnaw away at you every time you look at it!
Agree. Cut it out and re weld a new captive plate in. Simples.
#10
The plate MUST NOT be welded in . It has to be capable of movement or you will end up in every kind of difficulty
Christopher, I think Andrew means weld a new cage in and use a pattern plate which is left to float around inside the cage as original.christopher storey wrote:The plate MUST NOT be welded in . It has to be capable of movement or you will end up in every kind of difficulty
er yes! I thought that would be obvious. What I meant was to cut the top off the shoulder, and replace the captive plate, which as you say MUST be able to float. it will no doubt be retained in a cage of sorts which may have to be cut and rewelded in.christopher storey wrote:The plate MUST NOT be welded in . It has to be capable of movement or you will end up in every kind of difficulty
#14
Yes, it is in a horizontal cage rather similar to the vertical one for the door striker plates . It really is not worth going to the very extensive trouble involved in what is rather a dimensionally critical area if disturbed , when nuts can be glued in ( or indeed it might be possible to use rivnuts )
I have just been to check my car and it is a really easy job to get a nut on these bolts working through the cubby hole on the inside of the rear panel behind the seats. It may even be possible to remove the captive plate through here if you are a contortionist. Of course the problem comes if you have to take off the window pillar and drop the nuts down inside where no doubt they would rattle !
PaulColeman
#16
I like the rivnut idea that sounds worth pursuing. Anybody know what the thread size should be in that plate?
Cheers, Paul.
Cheers, Paul.
This is what the plate looks like from below:
http://s1287.photobucket.com/user/pauls ... sort=1&o=0
I would think it was not too difficult to drill out the spot welds from above, repair and plug weld back in.
PaulColeman
#18
Hmmm... yes maybe, I'll remove the paint and see if I can see them...
Cheers, Paul.
Cheers, Paul.
The captive plate must be allowed to float to avoid B Pillar alignment problems. When I first read your post, I thought about going in from the top but there are two thicknesses of material to cut through before you could get the captive plate out. This will be difficult. The cage holding the captive plate in place is spot welded along three sides (both ends and along a side). Looking at my shell, I would go in from the underside and using a Dremel, slit one end of the cage, pry open and slide out the captive plate. You can then make a new captive place and slide in place followed by closing up the cage. I wouldn't worry about welding the cage closed since the there will not be much force applied when installing the screws at the base of the B pillar.
Chris
Chris
#20
The screws, which are a chromed countersunk variety, are BD 22728/4 at both top and bottom. This does not tell us what thread they are, but as per usual, if you get in touch with Andy Rayner at Hutsons, I am sure he will be able to supply you with 8 of them - there are 2 top and 2 bottom on each side - and tell you what thread they are. I have a feeling they are 1/4 UNF but they could in fact be a BA thread, although I think this is less likely
