Door seals (rubbers)
broncorick
#1 Door seals (rubbers)
Post by broncorick » Sun Jul 15, 2012 3:38 am
I was wondering HOW you get the rubbers to fit back into the cantrails or do you just glue them on? I am in t he throes of a resto of a 62 FHC. Have buil a rotisserie for it and am thoroughly enjoying it. Will try to figure out how to post pics.
38E
Post by 38E » Sun Jul 15, 2012 5:35 pm
A '62 FHC should have a pre-formed 'C' channel section rail pop riveted around the front and rear side windows.
I believe some later models had the front rubber just glued on.
Clive, 1962 Coupe 860320
(sold)
Robert Hiland
#3 Door Rubbers
Post by Robert Hiland » Thu Nov 28, 2013 12:49 pm
I have found that the tool used to install splines in screened windows works well.
Simply insert the inside of the door rubber in the cantrail and run the wheel along the other side. It should slide right in ... no glue required. You may still have to use a dull slotted screw driver to complete the job at the ends.
Depending on the manufacturer, you should no problems.
I have found that rubbers made in the UK work best.
Good luck
Dave K
Post by Dave K » Thu Nov 28, 2013 1:52 pm
Make sure you wipe off the white residue from the extrusion before fitting them.
the doc
Post by the doc » Tue Dec 17, 2013 2:05 am
I too am in the throws of a resto and would like to know who provides the best door and bonnet rubbers ?
we are working hard to line all up but would hate to have all messed up once new rubbers are in place .
Gary
63FHC
887465
the doc
Post by the doc » Thu Dec 19, 2013 1:37 am
ANYONE??
Gary
63FHC
V12 Epyte
Post by V12 Epyte » Thu Dec 19, 2013 7:20 am
You could try these, http://www.coh-baines.co.uk/
My car was restored with seals from these people
the doc
Post by the doc » Thu Dec 19, 2013 2:24 pm
were the seals you bought and used the exact same profile as the ones you took off or did you get something smaller to ensure a better fit??
Gary
63FHC
887465
andrewh
Post by andrewh » Fri Dec 20, 2013 6:24 pm
Sorry to hijack your thread but I wonder whether you may help ? I am just about to fit my door seals also but have spotted that the seal retainers were taken off when the shell was sand blasted and have not been put back on. These are the seals stips on the bulkhead that seal the front edge of the door. Have you got any photos of how they fit please? I reckon they are pop riveted onto the bulkhead probably from the inside but any clarification would be much appreciated.
1962 3.8 Series One FHC
