2+2 cooling system
#1 2+2 cooling system
just returned from the big charity rally (500+cars ) only 2 2+2,s there question should my car have a plastic header tank on the bulkhead beside the wiper motor my car is 67 build eng.no.1e50570 the car Isaw today was 67 build eng.no 1e50900 odd and was fitted with the extra tank on the bulkhead can,t see one listed in the SNG cat. WAZZA
no your car shouldnt have a plastic tank on the bulkhead unless youre talking about the washer bottle no etype had plastic header tank anywhere the numbers youre giving arent engine numbers they are car numbers good for you doing the run in your car in high heat presumably hope you can follow this ok with no punctuation keep on trucking PETE
