Anti roll bar bush wear
johnben
#1 Anti roll bar bush wear
Post by johnben » Wed May 14, 2014 5:24 am
Hi Folks
I am hawking this subject around a bit but have not had much response. The car went for an MOT last week, it passed but the inspector stated that the N/S bush on the anti-roll bar would need replacing in the future. I checked and sure enough the bar was loose due to wear in the rubber bush the O/S was OK. This came as a surprise to me as I had replaced them three years ago when I did all the rear suspension. I suppose I have done less than a 1000 miles since. There appears to be two possible causes, the first is poor quality rubber bushes (SNG I think) or I have reassembled the rear suspension incorrectly which is exerting excess pressure on the bush. I am considering replacing with Poly bushes, any views please.
1954Etype
#2 Re: Anti roll bar bush wear
Post by 1954Etype » Wed May 14, 2014 6:19 am
Could be badly made part - too small or mounting tightened up in relaxed position. I have fitted rubber (Metalastik) and polybush with no issues. Just remember to only tighten the mount with the weight of the car on its wheels.
Angus 67 FHC 1E33656
61 OTS 875047
johnben
#3 Anti roll bar bush wear
Post by johnben » Thu May 15, 2014 4:47 pm
Hi Angus
Thanks for the reply I couldn't swear that these bushes were not tightened under load but it is unlikely as not being an experienced mechanic I tend to read the forums and have the manual ready on the big day. I think I will fit polybush as at least the inspector will know I have taken some action.
