#1 Speedo reading low
Posted: Thu Mar 20, 2014 4:30 pm
Hi all
Have just got my 3.8 FHC back on he road after a two year restoration. Car runs well but the speedo reads low. Indicates 18 mph/1000 rpm in top gear instead of 22.5 which I think it should. Rev counter has been checked against an electronic one is is pretty accurate. My speed has the number 6322/00 on the face, which believe to be correct for the 3.31 rear axle which my car has. The speedo is smooth and progressive in operation and appears to read 20% low up to 60 mph which is as fast as I want to go as the engine has only a few miles on it. Before the restoration the speedo did stop working which I traced to a worn out angle drive on the gearbox. I replaced that with a repro item from one of the UK suppliers, but the threads were too tight to allow it to be screwed fully onto the gearbox. I replaced it with a good second hand drive which worked but now I have the low reading. A bit baffling. Any thoughts much appreciated. Too many speed cameras to tolerate a low reading speedo.
David
David
